Please someone help me with a error message using HFSS v9.0
gecesars
Hi...
I´m new in HFSS and I can´t finalize my simulations cause everytime i see the same message:
"" filtro (D:/Documents and Settings/geraldo.cesar/Meus documentos/Ansoft/)
HFSSDesign1
[error] Initial mesh, process mesh3d : Error while opening or writing the mesh files. (11:27 set 27, 2007)
[error] Simulation completed with execution error on server: Local Machine. (11:27 set 27, 2007)""
Please, if someone knows what´s is happeing help me...
Regards.
Geraldo César
Re: Please someone help me with a error message using HFSS v
Hi
if your model and boundery and feed and analysis step are correct, I think you're using unregisted version or your model (radiation box) is too much big. it's better that you use HFSS v9.2 or 10
gecesars said:
Hi...
....Error while opening or writing the mesh files.
César
Tha't mean you've had the problem with your structure's geologique. For example may be you drew a L tube but you didn't creat the symetric zone. Try to re-draw the structure. Or post it here.
