please help remove the PWsteal.lemir.gen
freshair
Newbie level 1
Newbie level 1
pwsteal.lemir how to remove
hi, there, i have trojan PWsteal.lemir.gen in my pC, i am getting creazy.
my norton 2004 software indicate that it is at C:\windows\window32.dll, but i was not able to delete it. but it is there!
i have also tried to follow the removing instruction from the previous topic which posted at 12 august.
1. disable the restore
2. show all the hidden files etc
3.but task manager, i don't see the process EXPL0RER.EXE( fifth letter is 0 not O), only IEXPLORER.EXE, or explorer.exe?
what should i do, i am getting creazy! please help
freshair
Relax,
First of all I get give you the solution and I will, and your computer will be protected from one more virus, but who knows when the next one will strike. The easiest thing is to change computing habits, use a firewall like zone Alarm, ditch IE, and get either Opera or Mozilla FireFox, ditch Outlook Express, and get Eudora.
You see these are the softwares which are most vulnerable in Windows, be changing them you reduce the chances of getting infected.
So here is the solution to current problem, but I recommend that you should change your computing habits
go to
https://securityresponse.symantec.com/avcenter/venc/data/pwsteal.lemir.gen.html
