Please help, Problems with ADEXL on Fedora12
fcentur
Newbie level 1
Newbie level 1
I am using IC615 on Fedora12 (kernel 2.6.32.21-168.fc12.x86-64). I can setup the simulation, but Cadence freezes when I run it. If I kill virtuoso and run the comand by the comand line, I get the following error:
fcentur@vlsi2 ~$/home/software/cadence/IC615/tools.lnx86/dfII/bin/64bit/virtuoso -noautostart -mpssession virtuoso1345 -mpshost vlsi2 -log /home/fcentur/cds6/logs_fcentur/Job0.log -nograph -nostdin -axlChildIdFlag 0
/home/software/cadence/IC615/tools.lnx86/dfII/bin/64bit/virtuoso: symbol lookup error: /home/software/cadence/IC615/tools.lnx86/lib/64bit/libcdsChms_sh.so: undefined symbol: _ZTIN12OpenAccess_419oaChangeSetObserverE
How can I solve it ?
I had the same problem in Ubuntu. It is related to your OpenAccess installation. You need to make sure that you're using the OA version which came with the IC package. You must be setting OA_HOME variable, this might cause problems since different tools use different OA versions.
