Please help me with parallel ports! Thanks!
bulletrick
Newbie level 1
Newbie level 1
Hello. I just want to ask anyone the specific codes in Turbo C++/ Borland C++ to separately output a signal to the D0 - D7 pins of the parallel port.
My problem is that when i turn one pin ON, all other pins are also ON!
Please help... Thanx!
you must do read , modify and write operation
try this . i dont know Turbo C port access function prototypes ,
so i used pseduo types outp( int portAddr , BYTE value ) BYTE inp( int portAddr )
void SetBit( BYTE bitNO )
BYTE mask = 1 >> bitNO ;
outp( portADDR, inp(portADDR) | mask );
void ClearBit ( BYTE bitNO )
outp( portADDR, inp(portADDR) & ( ~mask ) );
good reply depends on the OS you have
try this one
here is the way to interface in C language
h**p://www.embeddedtronics.com:80/public/Electronics/minidaq/userport/UserPort.zip
download this file and unzip it
then copy Userport.sys to WINDOWS\SYSTEM32\DRIVERS
then run USERPORT.EXE
u will get a message driver started
Now u do programming in C/C++/JAVA and interface in XP or other version of Windows.
this one worked with me,for parallel port tutorials see
www.bibinjohn.tk
have you tried ANDing/ORing the bits?? to turn on bits, OR it with 1 and leave the rest with 0. to turn off bits, AND it with 0 and leave the rest with 1.
i hope i understood and answered your question.
1- **broken link removed** --> borland
2- **broken link removed** --> various language
3- take a llook to attach.
see this code
#include<dos.h>
void main()
outportb(0x378,0x02);
first u put userport in my previous post
then u run my programs given in my book, i explained full on that book, there is a section named getting started atleast read that one.
Also visit 'beyondlogic.org.' for a good explanation and sample code.
