hebu
Full Member level 4
I designed a single stage OPamp for SC filter in audio frequency, the sampling
frequency is 1MHz. The cap I use is around 2.5pF and 250fF, the input capacitance
of OPamp is around 3pF,(larger size to reduce flicker noise), The current consumption of opamp is only 120uA. The input signal should be small than 1.6V
peak to peak voltage(differential), and a 40KHz anti-aliasing filter is preceded the SCF.
My question is, do you think the 120uA current of OPamp is too small?
The technology is 0.35um.
