please help me read the opamp buffer datasheet
henrywent
Member level 5
Member level 5
china
Hello there,
please help me read the datasheet of a opamp buffer. Part of the datasheet is posted here. In the DG (differential gain) field, what does '' RL=150Ω to 0V '' mean ? why does volt appear in the unit of a resistor? AND what does DG=0.06% mean ? thank you for reply !
It means a 150 ohm resistor from the output to a 0 volt source
(or ground, if the two are the same). Two attributes of the load
are expressed here, its potential and series resistance.
