spicy_coder
Newbie level 2
Hi, first of all, hi to all as i am new on this forum.
I am Computer Science student and electronics hobbyist and i´m trying to make my PCB first board.
I have made a little electronic circuit and electronics schematic to make a little plant grow light controller,
i have not enough experience/confidence on my design and tried to make it as simple as possible, but still i have a feeling that is going to be a big fail, so if somebody with experience could give me some advice and at least help to me make it safe and avoid burning my house down it would be awesome.
Description of the device
- 24v input drives two power converters, MP1584 Buck converter board from china for 5v electronics and meanwell LDD-700L, this driver is used to drive two BXEB L0280Z led light bars.
- esp32cam board used as MCU, to take photos of the veggies, control and take data, show it a oled screen and upload it to a linux server.
- DHT22, 2 i2c lines for i2c devices (oled screen and one to expand in the future) and onboard ftdi, and boot pins to flash the esp on the go.
- I am trying to make it as cheap as possible, so its as small as i could do it and i am avoiding using smd components and use only through hole components to be easy soldering.
Questions
- i used 0,8mm separation between traces, 0,15 mm width for signal lines, and 0,8mm for power lines, as it is a bit more than the values that i get in a this trace width calculator using 18micrometers as Cu thickness, 24v and 1A, could be this the layer thickness or i am messing numbers from the fab page?
- i saw that the bottom part of the esp32 antenna should be outside of any pcb and preferably without any traces underneath, because of interference, but i plan to use a external antenna, should be concerned about interference anyway?
- Should 24v GND, MP1584 input and output share the same GND? i think so because 24v input is input for ldd driver, and i plan to dim the driver with the MCU so they should share the same GND, but this makes connect input and output ground of MP1584 directly, and i don´t know if this is safe.
- should be there any resistor between the ldd driver dim and the esp32 output?
- Is there anything dangerous because of crossing lines between positive and negative 24v 1A in top and bottom layers?
- Is there anything apart from the listed in the questions on the schematic or board that doesn´t make sense or it´s dangerous?
Thank you in advance for your time and help
Questions
