danriis
Hi all,
So I decided to fix my LG Flatron monitor and pulled the power+inverter combo board out.
The picture shows a normal board. Notice the blue component circled in Red, well that component is completely burned up on my board so I need to replace it. But how do I find a match? (I think it may be called a ceramic disc capacitor ???)
Since the burned component is identical to the one next to it, I figured the local electronics store could match it. However, I was instead told that there wasn't enough information written on the other ones to find a match.... huh?
Here is what it says on the other, identical, ones :
.1Y
S1 6KV 5D
The first line is hard to read, could be a dot could be a dash, then 1 or I and then probably the micro farad sign. I am pretty certain about the characters on the second line.
From looking at pictures this may be a ceramic disc capacitor, yes?
I hope someone out there can interpret the letters and numbers above and tell me what I need to tell the guy a the store to get the right part. See picture below.
THx soooooooo much in advance !
Dan
.1Y
S1 6KV 5D
Dan
