blooz
Advanced Member level 2
![Advanced Member level 2](/styles/images/ranks/glevel2.gif)
Hai the the code is as follows it compiles without error but the Waveforms when Simulated Doesnot match with Requirement .I Intended to design a mode 4 Counter but the simulation does take place but with wrong result
//Code mode 4 counter in verilog
// Title : No Title
// Design : verilog_systemc_parameters
// Author : Neural
// Company : Artificial_Resonance
// File : F:\My_Designs\Samples_72\verilog_systemc_parameters\compile\a1.v
// Generated : 01/23/11 13:13:12
// From : F:\My_Designs\Samples_72\verilog_systemc_parameters\src\a1.asf
// By : FSM2VHDL ver. 5.0.3.4
// Description :
`timescale 1ns / 1ps
module a1 (clk, out, reset);
input clk;
input reset;
output [1:0] out;
wire clk;
reg [1:0] out, next_out;
wire reset;
// BINARY ENCODED state machine: Sreg0
// State codes definitions:
`define S1 2'b00
`define S2 2'b01
`define S3 2'b10
`define S4 2'b11
reg [1:0] CurrState_Sreg0;
reg [1:0] NextState_Sreg0;
// Machine: Sreg0
// Next State Logic (combinatorial)
always @ (out or CurrState_Sreg0)
begin : Sreg0_NextState
NextState_Sreg0 <= CurrState_Sreg0;
// Set default values for outputs and signals
next_out = out;
case (CurrState_Sreg0) // synopsys parallel_case full_case
`S1:
if (clk)
begin
NextState_Sreg0 <= `S2;
next_out = 2'b01;
end
else
begin
NextState_Sreg0 <= `S1;
next_out = 2'b00;
end
`S2:
if (clk)
begin
NextState_Sreg0 <= `S3;
next_out = 2'b10;
end
else
begin
next_out = 2'b00;
end
`S3:
if (clk)
begin
NextState_Sreg0 <= `S4;
next_out = 2'b11;
end
else
begin
next_out = 2'b00;
end
`S4:
if (clk)
begin
next_out = 2'b00;
end
else
begin
next_out = 2'b00;
end
default:
begin
// trap state
next_out = 2'b00;
end
endcase
end
// Current State Logic (sequential)
always @ (posedge clk or posedge reset)
begin : Sreg0_CurrentState
if (reset==1'b1)
CurrState_Sreg0 <= `S1;
else
CurrState_Sreg0 <= NextState_Sreg0;
end
// Registered outputs logic
begin : Sreg0_RegOutput
if (reset==1'b1)
begin
out <= 2'b00;
end
else
begin
out <= next_out;
end
end
endmodule
![](https://obrazki.elektroda.pl/98_1295769571_thumb.jpg)
// Title : No Title
// Author : Neural
// Description :
input clk;
input reset;
output [1:0] out;
wire clk;
wire reset;
`define S1 2'b00
`define S2 2'b01
`define S3 2'b10
`define S4 2'b11
// Machine: Sreg0
next_out = out;
`S1:
if (clk)
begin
next_out = 2'b01;
end
else
begin
next_out = 2'b00;
end
`S2:
if (clk)
begin
next_out = 2'b10;
end
else
begin
next_out = 2'b00;
end
`S3:
if (clk)
begin
next_out = 2'b11;
end
else
begin
next_out = 2'b00;
end
`S4:
if (clk)
begin
next_out = 2'b00;
end
else
begin
next_out = 2'b00;
end
default:
begin
// trap state
next_out = 2'b00;
end
endcase
end
if (reset==1'b1)
else
end
if (reset==1'b1)
begin
out <= 2'b00;
end
else
begin
out <= next_out;
end
end
endmodule
