Please explain LIN Parameter, bit quantization.
jani12
Full Member level 1
We are using number of Local Interconnect Network(LIN) channels from Renesas RH850 / U2A16 Microcontroller in our embedded system. All LIN channels in our embedded system are Master.
What is LIN Parameter called bit quantization? I didn't find explanation of this parameter in LIN Controller user's manual.
I was provided LIN Controller Application Note for Renesas RH850 Microcontroller. Attached is section 2.4. It discusses some parameters. How are some of these parameters determined? For example, Number of segments (quanta) within a bit to set the resolution of the sampling point, Nspb.
--- Updated ---
bit quanta information is attached.
