Sheeraz Khan
Member level 3
60PPM & 1 PPM Out
Can anybody draw schematic of listed code?
; pulse_60.asm
; 22nd Oct 2004
; Output 1 pulse/min from 50Hz mains or 0.5Hz clock circuit
list P =3D 12F675
include "P12F675.inc"
errorlevel -305, -302, -306 ;MPLAB error suppression
__CONFIG _CP_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_OFF & _MCLRE_ON
bank0 macro
bcf status,rp0
bcf status,rp1
bcf status,irp
endm
bank1 macro
bsf status,rp0
bcf status,rp1
bcf status,irp
endm
mov macro litval,file
movlw litval
movwf file
endm
cblock 0x20
ticks
secs
temp1
temp2
t0_cnt
endc
#define led gpio,0 ;1 ppm LED
#define power gpio,1 ;mains on
#define mains50 gpio,2 ;50Hz in, INT
#define b0int gpio,4 ;out to 452
#define clock gpio,5 ;0.5Hz from clock module
org 0x00
goto start
org 0x04
goto isr
org 0x05
start bank1
call 0x3ff
movwf osccal
clrf ansel ;digital inputs
movlw b'00101110'
; 1 0.5Hz in
; 0 output to 452
; 1 /mclr
; 1 50Hz in
; 1 mains on/off
; 0 green LED, output
movwf trisio
movlw b'10000110'
; 1 pullups off
; 110 /128 TMR0 pre-scaler
movwf option_reg ;=3D ~32.768ms rollover 4MHz int RC = osc
bank0
clrf gpio
movlw b'00000111' ;GPIO 0,1,2 as digital
movwf cmcon
clrf tmr0
clrf intcon
bsf intcon,inte
clrf t1con
mov 0xff,tmr1l ;load TMR1 with -1
mov 0xff,tmr1h
mov .100,ticks ;2 second resolution
mov .30,secs ;1 minute
;=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
; Main loop, wait for input
main btfss power
goto battery
bcf intcon,intf
clrf tmr0
wt_lh btfsc mains50
goto chk_m1
wt_hl btfss mains50
goto chk_m2
bcf led
decfsz ticks
goto main
mov .100,ticks ;reload ticks
bsf led ;LED on 1/50th second
decfsz secs
goto main
mov .30,secs ;reload secs
call pulse
goto main
battery btfss clock
goto sec2 ;process if power off
btfsc power
goto main ;exit if power comes on
goto battery
sec2 bsf led
call ms5 ;LED on for 5ms
btfss clock ;wait for return high
goto $-1
bcf led
decfsz secs
goto battery
mov .30,secs
call pulse
goto battery
pulse bsf b0int ;50us pulse to 452
mov .252,temp1
incfsz temp1
goto $-1
bcf b0int
return
chk_m1 btfss power
goto battery
goto wt_lh
chk_m2 btfss power
goto battery
goto wt_hl
ms5 mov .249,temp1 ;5ms delay
mov 0x84,temp2
inct1 incfsz temp2
goto $-1
incfsz temp1
goto inct1
return
; Fault - TMR0 time-out
isr nop
t_loop bcf intcon,t0if ;approx 500us delay
btfss intcon,t0if
goto $-1
bcf intcon,t0if
return
end
; pulse_60.asm
; 22nd Oct 2004
list P =3D 12F675
bank0 macro
bcf status,rp0
bcf status,rp1
bcf status,irp
endm
bank1 macro
bsf status,rp0
bcf status,rp1
bcf status,irp
endm
movlw litval
movwf file
endm
cblock 0x20
ticks
secs
temp1
temp2
t0_cnt
endc
org 0x00
goto start
org 0x04
goto isr
org 0x05
start bank1
call 0x3ff
movwf osccal
movlw b'00101110'
; 1 0.5Hz in
; 0 output to 452
; 1 /mclr
; 1 50Hz in
; 1 mains on/off
movwf trisio
movlw b'10000110'
; 1 pullups off
bank0
clrf gpio
movwf cmcon
clrf tmr0
clrf intcon
bsf intcon,inte
clrf t1con
mov 0xff,tmr1h
main btfss power
goto battery
bcf intcon,intf
clrf tmr0
wt_lh btfsc mains50
goto chk_m1
wt_hl btfss mains50
goto chk_m2
bcf led
decfsz ticks
goto main
decfsz secs
goto main
call pulse
goto main
battery btfss clock
btfsc power
goto battery
sec2 bsf led
goto $-1
bcf led
decfsz secs
goto battery
mov .30,secs
call pulse
goto battery
mov .252,temp1
incfsz temp1
goto $-1
bcf b0int
return
chk_m1 btfss power
goto battery
goto wt_lh
chk_m2 btfss power
goto battery
goto wt_hl
mov 0x84,temp2
inct1 incfsz temp2
goto $-1
incfsz temp1
goto inct1
return
isr nop
btfss intcon,t0if
goto $-1
bcf intcon,t0if
return
end
