TimothyBoot
Newbie level 2
plcc44 to dip40
has anyone know how to convert plcc44 to dip40?
AL0117 said:first of all, check the datasheet of your device. The PLCC44 packages sometimes has some extra power pins, or not connected pins.
You can easy build an adapter with a plcc44 and dip socket, connecting together the corresponding pins with short wires. This will work reasonable up to 10-16 MHz clock speed. Youl could encounter problems at higher speeds.
Cheers, Al
