boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
I have built a plasma globe driver based on this circuit: http://www.stevehv.4hv.org/FBD/FBschematic.JPG
I powered the FET part of the circuit with 80V and the 555 part of the circuit with 16V
And here are the results: **broken link removed**
However I tried powering the FET part of the circuit with 100V DC and I smoked 2 TC4433 chips (8 pin pdip rather than TO-220)
Now I could try and test what is going on with my oscilloscope but it would mean smoking more of the chips. And it happens quite quickly so I would not have enough time to view any voltage spikes going into the TC4422 anyway.
Can anyone give me some tips as to what is likely to be causing the TC4422 to smoke?
Perhaps a kick back issue from the 100V side of the gate drive transformer sending a voltage spike into the output of the TC4422 that is exceeding the voltage rating of the output transistors inside it?
I could try the TO-220 package, but I am unsure whether I am likely to have the exact same issue with it smoking as well due to any voltage spikes.
Perhaps I should put a diode based snubber on the output of my TO-220?
