pamm2020
Junior Member level 1
Hi Friends,
Its exactly 6 years today as i started my career in VLSI field!!!
Started working with "SoC Subsysterm Design and Integration" moved to "IP verification" then worked on "RTL coding" of few Adapter IPs. Then again worked on RTL integration. All this happened in 2 years of time frame. Then due to recession I moved out of Frontend Domain to Backend where I got opportunity to work on Memory Compilers. It sounds bit messy initial days to understand what is GDS/LEF/ANTENNA/SI but it was very interesting and i could easily cope up with that in 3 months time. After working in Memory Compilers for 1 year, I got an opportunity to work in Standard Cell. Here from last 3 years I am working in Standard Cell library design -Schematic/layout design, Characterization, different EDA views generation like celtic/voltagestorm/verilog modelling etc...
Now I am realizing following drawbacks in current Standard Cell Library Design:
1> Work is more repeatative in nature.
2> Schematics we draw are for only small circuits, its nothing when compared to IO domain or Analog domain.
3> Layout work is very tedious in nature, sounds interesting when drawing first time but most of the time even a diploma guy can also do that
4> Characterization is very interesting but most of the time we spend time in firing jobs/monitoring jobs due to multiple PVT corners in package.
5> Major thing is the JOB opportunities. There are only countable companies who work in this domain and its very risky if one needs to hop a company in near future.
So, I am planning to move to Physical Domain since I have confidence that I worked on Standard Cells/Memories/RTL coding/SoC Subsysterm Integration/Verification, I myself realizing that I can do very well if I move to Physical Design - RTL to GDS2. Here I planning to work deeply in Timing Closure and Power Grid Analysis. I thought of moving to IO/Analog (ADC/DAC/PLL design) domain, but due to less confidence on CMOS circuit theory I don't want to take chance in IO/Analog domain.
As there are more job opportunities in Physical Design and also more chances of setting up a business in Physical Design, I am working towards learning Physical Design related stuff.
I hereby request you friends that is this move which I have planned is correct or not ? Please help me in deciding this. Your comments are most welcome!!!
Thanks
Thanks
