Planar Inverted_F Antenna
planar
Newbie level 3
Newbie level 3
I want to simulate a Planar Inverted-F Antenna (PIFA) in Microwave Office but i have a difficulty in the design also. Can anybody have me?
Regards,
Planar
It is not a better simulator for antenna simulation, try other software, HFSS or Microwave Studio. Good luck!
fdtd method is also good to simulate pifa
U can do it by MWO.. u must be smart becuase it´s not a 3D...
I suggest u to use CST, HFSS or even Ensemble (2.5D). The last one it´s more friendly than MWO.
Regards
Lupin
I designed a lot of PatchAntenna and Inverted-F-Antennas using MWO. In terms of S11, simulated vs measured plots were almost the same. But other parameters need more tuning.
Anyway, if you have just this software is a good starting point for a design. You have to combine more offen the simulation with measurement, which you have to do anyway.
First recommendation is to be careful in specifying the parameters of the enclosure.
use hfss i think it is much better
