grizedale
Advanced Member level 3
The Half-Bridge SMPS is a Zero-Voltage-Switch-ON converter.
-Because when a FET turns off, the primary magnetising current continues to circulate, and does so by forward biasing the opposite FETs parallel diode....
...then when this FET is turned ON, it obviously has zero volts across it , because its diode is conducting.
So why is the Humble Half-Bridge SMPS never , ever advertised as a "Zero Voltage Switched "technology?
