Placing layer information and PCB dimensions in gerber files using altium designer
viperpaki007
Full Member level 5
Full Member level 5
Finland
I want to place layer stack information and PCB dimensions in gerber files so they can be visible on side of PCB when viewing gerber. How can i do that in altium designer.
regards
Create a layer called drill drawing. In this layer add an out line for your board.
To add dimn
: place/dimension/linear : and then select points and keep adding more. you can select more options other than linear.
To add layer stack : place/ layer stack table/ and place it on layer.
please note it will come as how you defined in layer stack manager.
thanks,
keyur
