placing high to low level shifter
fragnen
Full Member level 4
Full Member level 4
Should low to high level shifter be placed in high voltage domain and why?
I'm not an exert on level shifters, however, I will state what seems obvious:
the level shifter has to go between the low and high levels, with the
zener diode / transistor / resistor that accomplishes the level shift
placed between the low and high levels.
i'm not sure what you mean by "be placed in high voltage domain".
why is always a good question
LaTeX Commands Quick-Menu:
