acika
Newbie
I am getting below error while doing place_opt in icc.
Information: Running stand-alone coarse placer in a separate process using temp directory '/tmp'. (PSYN-605)
Severe Error: Fatal error: Placer did not complete. (PSYN-375)
Error: psynopt has abnormally terminated. (OPT-100)
Error: place_opt results invalid due to placer failure.
Error: A Severe error has occurred. To ensure that the script does not continue, the value of sh_continue_on_error has been overridden to be false. Your script is being interrupted. To see the Tcl call stack for the part of your script which generated the Severe error use the error_info command. (CMD-103)
Error: Severe error encountered
Use error_info for more info. (CMD-013)
What is the root cause of this error?
