rohithkrishnan
Junior Member level 3
- Joined
- Aug 10, 2016
- Messages
- 31
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 8
- Location
- India
- Activity points
- 189
Tried separate filtering of PIR drain voltage? E.g. RC filter 10k/100µF.I've tried using a battery to power the Circuit.
What resistor divider? There is none.Is the resistor divider from source to ground is enough
When i to probe at output of second stage amplifier, a noise with 0.5Hz is seen which is causing false detection
It would be helpful to see the full picture. At worst case the comparator is driving a load with a considerable current consumption, e.g. a LED or a relays. Parasitic feedback can happen either through insufficiently filtered power supply or ground voltage drop.Also if the comparator stage in the app note is present (it is not shown in this thread) might test whether
switching noise injection is the stimulus that the LF pole and gain turns into oscillation.
