Pins that function as both inputs and outputs
aeneas81
Junior Member level 1
Dear all,
could anyone please teach me how to create pins that can be use as input pin as well as output pin (in VHDL)? I've tried using:
twowayPin : INOUT std_logic_vector(63 DOWNTO 0);
but whenever i compile i got the follwing warning:
Warning: TRI or OPNDRN buffers permanently enabled
and the default signal has become all ZZZZZZZZZZZ
if i try to simulate a data input, it will give a warning that signal contention happens..
pls help pls help... thank you very much
Hello aeneas81,
take a look at the following code:
ENTITY bidirektional IS
PORT( en_ab, en_ba: IN std_ulogic;
dbus_a: INOUT std_logic_vector(7 DOWNTO 0);
dbus_b: INOUT std_logic_vector(7 DOWNTO 0) );
END bidirektional;
ARCHITECTURE behave OF bidirektional IS
BEGIN
bidir_module: PROCESS(en_ab, en_ba, dbus_a, dbus_b)
BEGIN
-- write from port a to port b
IF ( en_ab = '1' AND en_ba = '0' ) THEN
dbus_b <= dbus_a;
dbus_a <= (OTHERS => 'Z');
-- write from port b to port a
ELSIF ( en_ab = '0' AND en_ba = '1' ) THEN
dbus_a <= dbus_b;
dbus_b <= (OTHERS => 'Z');
-- Tristate port a and b
ELSIF ( en_ab = '0' AND en_ba = '0' ) THEN
-- Both ports are enabled
ELSE
dbus_a <= dbus_b;
dbus_b <= dbus_a;
ASSERT FALSE REPORT
"Both Tristate Buffer are enabled!" SEVERITY NOTE;
END IF;
END PROCESS bidir_module;
END behave;
Bye,
cube007
thanks dude, i'll try on the code. by the way, what's a std_ulogic type?
I've found the answer myself. Thanks a lot!
The std_ulogic type
This type is used to represent the value of a digital signal in a wire. For general use, you probably want the std_logic instead. A signal or variable of this type can take on the following values:
'U': uninitialized. This signal hasn't been set yet.
'X': unknown. Impossible to determine this value/result.
'0': logic 0
'1': logic 1
'Z': High Impedance
'W': Weak signal, can't tell if it should be 0 or 1.
'L': Weak signal that should probably go to 0
'H': Weak signal that should probably go to 1
'-': Don't care.
The basic VHDL logic operations are defined on this type: and, nand, or, nor, xor, xnor, not. They can be used like the built-in operations on the bits.
cube, u really made my day!!! thank you so much!! finally i managed to solve a large problem with my design. Thanks! n god bless
Hello aeneas81,
You’re welcome. I advise you to get some VHDL books/ebooks for consulting. You can find some of these in the ebook Section.
Bye and happy coding,
cube007
