itsfanidotcom
Member level 5
![Member level 5](/styles/images/ranks/dlevel5.gif)
hi there,,
i need to connect the microcontroller 89c51 to the mobile t630 using the serial port of mcu, and serial cable of mobile DCU11 cable...
i need to know which pins of the dcu11 serial cable will be used for Tx and Rx and ground.. and which pins should i make short to avoid handshaking... if anyone know plz contact....
