cyaniccypher
Newbie level 5
I am just wondering if there is anybody here that has had this issue with their circuits. Also how likely is it that this effect will add distortion/noise to the output of an audio amplifier even if it is not used in the audio path but only for decoupling purposes of MOSFETS, op amps, and also used as power supply capacitors.
Kemet claims that their **broken link removed** of ceramic capacitors significantly reduces this piezoelectric effect. Does anobody have experience with this?
