The top is mirrored and could do with some tidying up.
Are you going to make this board yourself or get it made somewhere cheap? You may need to adjust the size of your pads as you have a very small amount of land left after the hole which will lead to very little solder to form a good joint.
Why have you hatched the copper? It will make it harder for you to etch yourself.
