davidmumford
Newbie
I bought Borden Radio's Pickard crystal radio kit, assembled it with my grandson, hooked an antenna to the roof and pounded a pipe into the ground. Something amiss, don't even get static. Antenna is 18 gauge steel wire, about 10 feet high, 50 feet long, but with longish connectors to radio, and in a forest. Grandson wound the coil backwards but don't see why this makes a difference. My car radio gets some half dozen AM stations, some better than others. Kit has a brass rod to connect to coil at variable points after sanding off the enamel coating, fixed capacitor (120 pf). "Headphone" is a one ear type high impedance crystal plug. Connections are wire to screw, not soldered. What to check to show what's wrong? Growing up 75 years ago, I made one using a crystal diode that worked great and I wanted to show my grandson that the air is full of invisible signals and explain AM to him.
