Pick and place text file from eagle
shrutib
Hello,
I need a pick and place .txt file and I have used Eagle for creating PCB board. Is these a way to get this file directly similar to CAD?
first select thi grid unit you want to export (mm/inch/mil)
Board: file -> export -> partlist -> "filename.txt"
This should be enough.
You also can look for eagle scripts or eagle ulp to do this.
Klaus
