picall software problem v0.12e and v0.14beta
hakan
Member level 2
Member level 2
picall software
i've bought a pic16pro programer. and i want to use it with picall software but it does not work.
i checked all hardware and tested pin by pin. hardware is o.k. i use win-xp. while i was testing hardware, software gave response. i tried it with hardware test buttons.
is there anybody there who have exparience in picall software?
does it realy work or not?
do you have another better solution to use picpro hardware with?
  • p16pro.pdf
programa picall
The topic is all ready replyed by two members where you post it
MICROCONTROLLER DESIGN
regards
fragrance
Pic16pro programmer work very fine
Incrase Time delay in:
Settings>Hardware Setup/Test
First disible AutoAdjust
Incrase Prog Delay
Incrase MS_Prog_Delay
Tune this values and find good values for your PC
Cable to PC long aboat 1m is OK
On my PC ( 500MHz ).
Prog Delay=4
MS_Prog_Delay=120
