sztibi82
Full Member level 3
Hi All, I try to put the PIC24F04KA200 into deep sleep for about 1 minute and then wake it up.
For now I didn't manage to make the controller to go into deep sleep at all.
The flags are set as follow:
the routine for starting the deep sleep are:
Alternatively I tried this
please can advice what to do to get into deep sleep.
// FGS
#pragma config GWRP = OFF // General Segment Code Flash Write Protection bit (General segment may be written)
#pragma config GCP = OFF // General Segment Code Flash Code Protection bit (No protection)
// FOSCSEL
#pragma config FNOSC = FRCDIV // Oscillator Select (8 MHz FRC oscillator with divide-by-N (FRCDIV))
#pragma config IESO = ON // Internal External Switch Over bit (Internal External Switchover mode enabled (Two-Speed Start-up enabled))
// FOSC
#pragma config POSCMOD = NONE // Primary Oscillator Configuration bits (Primary oscillator disabled)
#pragma config OSCIOFNC = OFF // CLKO Enable Configuration bit (CLKO output signal active on the OSCO pin; primary oscillator must be disabled or configured for the External Clock mode (EC) for the CLKO to be active (POSCMD<1:0>))
#pragma config POSCFREQ = HS // Primary Oscillator Frequency Range Configuration bits (Primary oscillator/external clock input frequency greater than 8 MHz)
#pragma config SOSCSEL = SOSCHP // SOSC Power Selection Configuration bits (Secondary oscillator configured for high-power operation)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor Selection (Clock switching is disabled, Fail-Safe Clock Monitor is disabled)
// FWDT
#pragma config WDTPS = PS32768 // Watchdog Timer Postscale Select bits (1:32,768)
#pragma config FWPSA = PR128 // WDT Prescaler (WDT prescaler ratio of 1:128)
#pragma config WINDIS = OFF // Windowed Watchdog Timer Disable bit (Standard WDT selected; windowed WDT disabled)
#pragma config FWDTEN = ON // Watchdog Timer Enable bit (WDT enabled)
// FPOR
#pragma config BOREN = BOR3 // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware; SBOREN bit disabled)
#pragma config PWRTEN = ON // Power-up Timer Enable bit (PWRT enabled)
//#pragma config BORV = 18V // Brown-out Reset Voltage bits (Brown-out Reset set to lowest voltage (1.8V))
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RA5 input pin disabled)
// FICD
#pragma config ICS = PGx2 // Reserved (PGC2/PGD2 are used for programming the device)
// FDS
#pragma config DSWDTPS = DSWDTPSF // Deep Sleep Watchdog Timer Postscale Select bits (1:2,147,483,648 (25.7 Days))
#pragma config DSLPBOR = ON // Deep Sleep Zero-Power BOR Enable bit (Deep Sleep BOR enabled in Deep Sleep)
#pragma config DSWDTEN = ON // Deep Sleep Watchdog Timer Enable bit (DSWDT enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define FCY 4000000
#define TRUE 1
#define FALSE 0
#include "xc.h"
#include <p24F04KA200.h>
#include <libpic30.h>
void DeepSleepConfiguration(void)
DSCONbits.DSEN = 1;
asm("nop");
asm("nop");
asm("nop");
asm("pwrsav #0");
asm("bset DSCON, #15");
asm("nop");
asm("nop");
asm("nop");
asm("pwrsav #0");
