PIC18F45K80 Timer 0
T_max = fixed_prescaler x max_selectable_prescaler x 2^counter_bit_width / fosc
Klaus
Klaus
Fixed prescaler _ five bit
2^counter_bit_width / fosc =2^8/20 MHz
What would be max_selectable_prescaler?
Is the input frequency 20MHz for Timer 0?
If I needed to know this .. have have to read the datasheet.
But you don´t want me to read the datasheet for you?
Klaus
hello,
look at the mikroE tool for Timer
18F timer0 16bits -> maxima is 3355mS with prescaler 1/256
or with an excel sheet
with prescaler 1/8 -> divide by 32
    Djsarkar
Klaus
I don't understand your formula
lets assume Timer 0 with 8 bit prescale , fosc = 2 Mhz
fixed_prescaler = 1 : 32
max_selectable_prescaler = 1:256
2^counter_bit_width/ fosc = 2^8/ 2000 000 = 256/ 2000 000 = 0.000128
T_max = 1/32 * 1/256 * 0.000128 = 0.03125 * 0.00390625 * 0.000128 = 0.000000015625
I did not verify your values..I just use them:
What I meant is:
T_max = 32 * 256 * 0.000128s = 1.048s
What I meant is:
I want to verify time
Fosc/4 with an 8MHz clock, that is 2MHz.
I have attached page From datasheet max_selectable_prescaler = 1:256
and I am setting fixed_prescaler = 1 : 32
A fixed prescaler is fixed, thus and can´t be "set". Some microcontroller have, some don´t. I´m not familiar with your microcontroller. Read the datasheet.
You may set the "selectable" prescaler to 1:256.
Klaus
Klaus
Thanks K, I have looked datasheet I don't think there is fixed prescaler option available
What I meant is:
8 bit Timer with 1:256 Prescale value
T_max = 256 * 0.000128s = 0.0032768s
We need to load value into the TMR0 registers (low 8 bits into TMR0L and high 8 bits into TMR0H).
What would be timer register value for 0.0032768s ?
I can´t answer without reading the datasheet.
I tried, but now I recognize that in the headline you talk about PIC18F45k80, but the uploaded page is from PIC18F66K80.
So I opened PIC18F66K80 datasheet...and Fig. 13-1 and Fig. 13-2 clearly shows "Fosc/4" as clock input. Which is a fixed 1:4 divider.
Fosc never - undivided - comes to the counter.
Klaus
hello,
see post#7 !
=> 3 276,8 µS
//Timer0  16bits !
//Prescaler 1:1; TMR0 Preload = 49151; Actual Interrupt Time : 3.277 ms
void InitTimer0(){
  T0CON     = 0x88;
  TMR0H     = 0xBF;   //191
  TMR0L     = 0xFF;   /255
  GIE_bit     = 1;
  TMR0IE_bit     = 1;
i did not see any Postscaler for Tirmer0 ...so
20MHz --> 4/20= 0.2µS per cycle
TMR0 value= (0xBF<<8) +255 = 48896 + 255 = 49151
(65536-49151) *0.2 = 3276.8µS
