aqua_life
Newbie level 6
Hello,
First of all I want to thank you everyone that will try to help me solving this problem.
During last years I have been developing projects for Automotive applications using PIC18 products.
Since the projects need CAN communication with the vehicle I have been using PIC18F25K80.
We have simple projects that the PIC only transmit up to 10 CAN messages and when we program 20 PIC´s all of them work correctly.
However we have other project that the PIC has to transmit 15 CAN messages and when we program 20 PIC´s half of them don´t work correctly. The program is always running in the PIC because we have other outputs (i.e. PWM) and these are working however CAN communication just don´t work on half of these.
We already tried to program the PIC again, same result, we already tried to replace all other components on the PCB without success (oscillator, mcp2551, etc).
So, when we program 20 PIC18F25K80-I/SS and we test them only half of them is working correctly on CAN communication.
The PIC´s that aren´t working correctly we use them for other project also with CAN but with less messages and it work perfect.
We have a development board with a 18F25K80-I/SP and during development of projects we never had any problems. So, maybe problem is with I/SS processors and not with I/SP processors.
I sincerelly thought that maybe this batch of processors might be faulty and I ordered 20 PIC18F26K80-I/SS which is very similar only memory size is different and I have the same problem. I program the 20 PIC´s and only half of them work with this program. The others must program with a simpler CAN project to work.
What should I do ? Any ideas ?
Do you know any Microchip technical support contact to ask them if any other customer with these PIC´s has same problem ?
Thanks for your help
