[PIC] Pic16f877a & SIM300 (Monitor & control device using SMS)
KVN1477
Junior Member level 3
hi
i am doing project to monitor & control device using PIC16F877A & SIM300 GSM MODEM in micro c pro compiler.
when i compile the program a warning is displayed like"RPI bit must be set manually"..
pls help me
It is "IRP_bit must be set manually to access xyz string" Wherever strings are used in code like LCD display, etc... use
Code C - [expand]
IRP_Bit = 1; //before instruction related to string handling
IRB_bit = 0; // after the instruction
It this doesn't solve the problem then use CopyConst2Ram() function.
