pic16f877a + nokia 3310 lcd
dtr
Newbie level 2
Newbie level 2
Sri Lanka
IM Dilan, I try to work with pic16f877a and nokia 3310 lcd. I tryed to code for print a string using mikroC. but i fail. Please explane some simple sample code for it(mikroC).
Thanx.
MODERATOR ACTION: Wrong Section
Here is a simple example code for the Nokia 3310, PIC and MikroC:
You may need to adapt the code to your specific connections between the Nokia 3310 and the PIC16F877A.
Hope the example helps.
BigDog
If using Hi-Tech compiler, where can I get or learn about the Nokia3310_Out function on MikroC?
I'm not aware of MikroC having any builtin functions for the Nokia 3310.
If you are using Hi-Tech C Compiler you could adapt the above Nokia 3310 library or another available library.
BigDog
Thanx bigdogguru.......................
