pic16f86 -want to make 2 digit BCD counter
exotic-13
Newbie
Newbie level 1
i wanna make a counter that goes from 00 to 59 using two bcd displayers , how can i do this and please i need some youtube channels that would help improve myself .
the program is the following :
void main () {
TRISB=0;
for(i=0;  i<=5;  i++);
{    for(j=0;  j<=9; j++);
        {  PORTB=j; i<<4;
          delay_ms(1000);
i=i++
[code tags added by moderator]
void main () {
TRISB=0;
        {  PORTB=j; i<<4;
          delay_ms(1000);
i=i++
show your schematic ....
I can suppose, the 2 BCD displayers are connected on PORT B
MSB on B7..B4 (0 to 5 ) and LSB on B3 ..B0 (0 to 9)
don't increase "i" in the loop, it is allready done inside "for" instruction
void main ()
do
 TRISB=0;
   for(i=0;  i<5;  i++);
       for(j=0;  j<9; j++);
         PORTB=( i<<4 )  |  j ;      // combine the two  i=MSB and  j=LSB
          delay_ms(1000);
while(1);
Also the "i<<4;" doesn't do much other than waste a few cycles.
Please show us your real code.
Susan
As an aside this can be done as a HW only solution in case you ever
need it (1 chip, in this case 3 digits, 7 segment output data) -
1634859593969-png.134176
This was an done on a ARM core part that has fabric inside to create other
digital HW functions, verilog was used for actual synthesis inside part.
The BCD to 7 seg was done via a simple LUT, as you can see on
above chip internal schematic.
Regards, Dana.
