zubusha
Newbie level 5
Remote Controled AV Switch Using PIC16F84A And Few Parts.
I Have Made This Inside Normal Selector Available In The Market.
Source Code Mainly From There Are Lot Of Protocols There Read It.
Codes Can Be Changed To Use On Any Remote, First You Have To Get The Codes.
If you don't know the code of ur remote use winlirc to get the code and work it out. You will have to make lot of note's. u have to make a small circuit (Included In The Rar File) for it and connect it to ur pc using serial cable
Start WinLiRC
Click On "Reconfigure"
Raw Codes And Press Any Key On Remote U Will Get The Raw Code's In The Box Copy And Calculate The 1's 0's And Try It Ur Self ( All U Will Get There Is Timming Of Each Pulses)
I Have Done And Example On "Codes.xls" Open It Figure It Out. Thanks.
WinLirc You Can Download ("winlirc-0.6.5" Not New One's) From
And Lot More Info From
All Files Are Included And Sorry No PCB Design I Have Done This On A Normal Board.
Any Comments Are Welcome Zubusha[at]yahoo[dot]com
Here Is The File.
http://users.telenet.be/davshomepage/
Start WinLiRC
http://winlirc.sourceforge.net/
http://www.lirc.org/
Here Is The File.
http://www.megaupload.com/?d=ZNMKQ9RU
