prateek_k_chd
Member level 5
Hello folks !
I've just moved from AtMegas to PICs.And I just baked my first 877As.
I suspect this was because of faulty board design,as some other thread here states that isolation of ICSP pins is needed,which was lacking.
I made a simple board (a 4 digit counter with 7 seg LEDs) with 16f877a as the uC.
I did not isolate the PGC (which goes to a LED via a resistor).There's nothing connected to PGD,and MCLR is pulled up to Vcc by a 4k7 resistor.The GND and VCC pins were connected to programmer directly.
So when I connected the programmer,the PIC burned out.
Later,I tried to program another 877A (using the ZIF on my USB programmer) but the programmer was connected to that board via ICSP,and then a BC557 on the programmer popped out like a popcorn
So can you people please tell me the appropriate way to isolate the ICSP pins? Or do you believe this problem can be because of any other reasons ?
Please pardon my paranoia,I'm on a schedule here and I never expected my desk to look like a kitchen platform.
Thank you so much !!
:smile:
:smile:
