T
treez
Hello,
I am writing MPASM code which should make GPIO,1 of PIC10F200 an output low for 10ms, then an input for 790ms.
This is repeated over and over.
However, the GPIO,1 pin does not become an input when it should......it actually stays as an output low.
-I know this because there is a 47K pull-up resistor on this pin, and it does not pull the pin up.
Do you know what i am doing wrong?
(Is it something to do with the ReadModifyWrite?)
....Do i have to just do a few dummy read instructions (eg, btfsc GPIO,1 nop nop ) after setting it to an input to make it really become an input?
By the way, here is the code....
;vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
list p=10F200 ; list directive to define processor
#include <p10F200.inc> ; processor specific variable definitions
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF
#define PIN_TRIGGER 0
#define PIN_SYNC 1
#define PIN_PHASE 2
#define PIN_FPM 3
;VARIABLE DEFINITIONS
sync_phase_FLAG EQU 0x13 ;insync of bit 0 is clear
FPM_FLAG EQU 0x14 ;FPM=75 if bit 0 is clear
ACDC_FLAG EQU 0x15 ;AC if its bit one is set
counter EQU 0x15 ;counter for delays
counter1 EQU 0x17
counter2 EQU 0x18
counter3 EQU 0x19
counter4 EQU 0x1A
count EQU 0x1B
phase_REG1 EQU 0x1C
phase_REG2 EQU 0x1D
ORG 0xFF ; processor reset vector
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
ORG 0x000 ; coding begins here
movwf OSCCAL ; update register with zero
;vvvvvvvvvvvvvvvvvvv OPTION REGISTER vvvvvvvvvvvvvvvvvvvvvv
start
movlw 0b11000111
option ;set option register
;SET PORTS UP AS INPUTS/OUTPUTS.
movlw 0b00001110 ;Set ports to input or output
tris GPIO
nop
;Initiate the ports
bcf GPIO,PIN_TRIGGER ;Ensure trigger output low
;start up delays
call delay_195ms
call delay_195ms
call delay_195ms
call delay_195ms
;Check for ACDC input
;VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
;0000000000000000000000000000000000000000000000000000000000000000000000000
FPM60_INSYNC
;Send trigger
bsf GPIO,PIN_TRIGGER
call delay_10us
;Set sync pin to an output
movlw 0b00001100
tris GPIO
nop
;Send sync pulse
bcf GPIO,PIN_SYNC
call delay_10ms
;Set sync pin to an input
movlw 0b00001110
tris GPIO
nop
call delay_195ms
call delay_195ms
call delay_195ms
call delay_195ms
call delay_30ms
goto FPM60_INSYNC
delay_10us
nop
nop
nop
nop
nop
nop
nop
nop
nop
retlw 0x00
delay_2ms
; clrwdt
movlw 0x04 ;4
movwf counter1
kkk
movlw 0xA7 ;167
movwf counter
jjj
decfsz counter,1 ;INNER LOOP=501us
goto jjj
decfsz counter1,1
goto kkk
retlw 0x00
delay_5ms
; clrwdt
movlw 0x0A ;10
movwf counter1
mmm
movlw 0xA7 ;167
movwf counter
nnn
goto nnn
decfsz counter1,1
goto mmm
retlw 0x00
delay_10ms
; clrwdt
movlw 0x14 ;20
movwf counter1
qqq
clrwdt
movlw 0xA7 ;167
movwf counter
ppp
goto ppp
decfsz counter1,1
goto qqq
retlw 0x00
delay_30ms
movlw 0x3C ;60
movwf counter1
sss
; clrwdt
movlw 0xA7 ;167
movwf counter
rrr
decfsz counter,1 ;INNER LOOP = 501us
goto rrr
decfsz counter1,1
goto sss
retlw 0x00
delay_50ms
movlw 0x64 ;100
movwf counter1
ttt
; clrwdt
movlw 0xA7 ;167
movwf counter
vvv
goto vvv
decfsz counter1,1
goto ttt
retlw 0x00
delay_195ms
movlw 0xFF ;100
movwf counter1
XXX
; clrwdt
movlw 0xFF ;167
movwf counter
YYY
goto YYY
decfsz counter1,1
goto XXX
retlw 0x00
END
