nomad13
Full Member level 3
rs232 non-serial port
Yesterday I've done a PIC programmer that I found on the net.
It is based on KIT 149bc. I connect it to my laptop that has no serial port. Run the software and it works.
The original diagram was modified. I remove the FTDI chip because I'm planning to use a USB to RS232 converter cable that I have. The pcb I made was single sided.
I've tried many serial programmer but this is the only one that works with a USB to RS232 converter cable.
