T
treez
Hi
We have a PIC16F18856 with Vcc = 3v3.
The code takes pin A0 high…however, pin A0 only goes high when the pin is totally unloaded.
If I load it with 10k, it goes up to about 0.1v
If I load it with 92k, it goes up to about 0.5v
If I load it with 174k, it goes up to around 0.9v
Does this sound like a pin suffering ESD damage?
The micro works and the other pins work fine.
Or would you say the pad for A0 pin is likely to be almost dry joint and offering high resistance to the external circuit?
