pic microcontroller port pins changing
svhanu4010
Newbie
i want to interface both spi and i2c devices in same pic microcontroller
suppose if we have a possibility to change pins of i2c how can i
plz help me
Depends on which PIC you have.
Some PICs have alternative pin functions or pin mapping - others do not.
The datasheet for you PIC will have the answer, but without knowing exactly which PIC you use, it is impossible for anyone here to answer
You can implement either software I2C or software SPI using arbitrary GPIO pins. Or use a modern PIC with two MSSP interfaces.
At first sight, you could share the Data pin for both, but Clock pin should be dedicated for each one, summing therefore 3 pins for both devices.
No reason to use h/w I2C perepherials. I suggest you to use s/w. It is available in MikroC. So you will be able to assign any free pins for I2C purpose.
But SPI is a high speed interface and I prefer to use it by h/w. Much faster.
can you give some example code thereby i can understand clearly
can you give example code for defining the SDA and SCL pins to other pins
I can provide an example of s/w I2c library that I currently using, but it is for STM8/32. Not for PIC. And it is really complicated.
hi svhanu,
example code for I2C Master....PIC16f877A
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
#include<pic.h>
#define _XTAL_FREQ 10000000
void lcd_cmd(unsigned char cmd)
    PORTB=cmd;
    PORTDbits.RD0=0;
    PORTDbits.RD1=0;
    PORTDbits.RD2=1;
    __delay_ms(1);
        PORTDbits.RD2=0;
void lcd_data(unsigned char dat)
    PORTB=dat;
    PORTDbits.RD0=1;
    PORTDbits.RD1=0;
    PORTDbits.RD2=1;
    __delay_ms(1);
    PORTDbits.RD2=0;
void lcd_ini()
    lcd_cmd(0x38);
    lcd_cmd(0x01);
    lcd_cmd(0x80);
    lcd_cmd(0x0c);
void lcd_str(unsigned char *p)
    while(*p != '\0')
        lcd_data(*p);
        p++;
void str(unsigned char x)
SSPCON2|=x;   //star condition
while((PIR1&0x08)==0x00);  //polling
PIR1&=~0x08;             //clear flag
void add(unsigned char x)
SSPBUF=x;             //slave addrs
PIR1&=~0x08;
void main(){
unsigned char s[]={"sumit"};
int i;
TRISC=0xff;
SSPCON=0X28;        //enable +mode
PORTC=0xff;
lcd_ini();
SSPADD=24;        //baud rate
SSPSTAT=0X80;    //slew rate
str(0x01);
for(i=0;i<5;i++)
add(s[i]);
str(0x04);
while(1);
Since PIC16F877A has only one hardware module that can do SPI or I2C, but not both at the same time, then you either need to change PIC, or use software for one or other function.
I know nothing about software I2C or software SPI.
If it were me, I would change to a better PIC
Attached s/w I2C library.
View attachment SW_I2C.zip
Example of use:
#include "SW_I2C.h"
I2C_SW_InitStructTypeDef I2C_Struct;
	// Init I2C
I2C_Struct.delay_func = delay;
I2C_Struct.SCL_GPIO = GPIOB;
I2C_Struct.SDA_GPIO = GPIOB;
I2C_Struct.SCL_PIN = GPIO_Pin_6;
I2C_Struct.SDA_PIN = GPIO_Pin_7;
I2C_Struct.DelayValue = 50; //130kHz clock
delay is a function. Also, you need to change or declare your own functions like a PIN_OFF, PIN_ON, PIN_IN which I used in this driver.
