D1_DRE
Member level 3
![Member level 3](/styles/images/ranks/dlevel3.gif)
Hello all
Please I have the following questions about clocking timer0 or timer1 using an external clocking signal (i.e on pin T0KI or T1KI):
1. what is the maximum frequency supported,
2. Can I supply it with 5Mhz or 9Mhz xtal and it will work
2. The block diagram of the timer says no but will the frequency from the external clock source be divided by 4 also?
Thanx
Thanx
