[PIC] PIC+MAX7219 Dot matrix Led Display
HAMAYOUN AHMAD BHATTI
Junior Member level 1
Hi
I am trying to interface PIC+MAX7219 Dot matrix Led Display.
but until now i can not build any library for 7219 display.:cry:
can anyone help me in building a library for PIC16f877a+MAX7219 Dot matrix Led Display.
Header:
#define CS														GPIOA, GPIO_Pin_2
#define MAX7219_NoOperation						0xA0
#define MAX7219_DecodeMode						0xA9
#define MAX7219_Intensity							0xAA
#define MAX7219_ScanLimit							0xAB
#define MAX7219_ShutDown							0xAC
#define MAX7219_DisplayTest						0xAF
typedef struct
	unsigned char DecodeMode;
	unsigned char Intensity;
	unsigned char ScanLimit;
	unsigned char ShutDown;
}MAX7219Init_TypeDef;
unsigned char MAX7219_Init (MAX7219Init_TypeDef * MAX7219_InitStruct);
void MAX7219_StructInit (MAX7219Init_TypeDef * MAX7219_InitStruct, unsigned char DigitsPerChip);
void MAX7219_DrawDigitSerial (unsigned char * Digit);
void MAX7219_DisplayTestVoid (unsigned char Enable);
void MAX7219_SetIntensity (unsigned char Intensity);
void MAX7219_Power (unsigned char PowerState);
void MAX7219_DrawCharSerial (unsigned char CHAR, const unsigned long (*FONT)[]);
and code:
#include "MAX7219.h"
#define MAX7219_SPI								SPI1		//interface definition
#define MAX7219_MaxCountValue			12			//maximum vaule of chips in serial to scan
/* You can manualy assign the value of chips in serialy connected here*/
unsigned char ChipsInSerial=8;	//otherwise search procedure will be needed and loop must be closed
unsigned char DigitsPerChip=8;
unsigned char MAX7219_WriteReg (unsigned char Reg, unsigned char Data);
	unsigned char cnt=0;
	unsigned char tmp=0;
	if (ChipsInSerial==0)
		PIN_OFF(CS);
		for (tmp=0;tmp!=MAX7219_MaxCountValue;tmp++) SPI_SendByte(MAX7219_SPI, MAX7219_NoOperation);
		PIN_ON(CS);
		PIN_OFF(CS);
		tmp=0;
		while ((tmp!=Reg)&(cnt<MAX7219_MaxCountValue))
			tmp=SPI_ReadByte(MAX7219_SPI, Reg);
			SPI_SendByte(MAX7219_SPI, Data);
			cnt++;
		PIN_ON(CS);
		ChipsInSerial = cnt-1;
	else
		PIN_OFF(CS);
		for (tmp=0;tmp!=ChipsInSerial;tmp++)
			SPI_SendByte(MAX7219_SPI, Reg);
		PIN_ON(CS);
	return ChipsInSerial;
	MAX7219_DisplayTestVoid(0);
	DigitsPerChip = MAX7219_InitStruct->ScanLimit+1;
	MAX7219_WriteReg(MAX7219_DecodeMode, MAX7219_InitStruct->DecodeMode);
	MAX7219_WriteReg(MAX7219_Intensity, MAX7219_InitStruct->Intensity);
	MAX7219_WriteReg(MAX7219_ScanLimit, MAX7219_InitStruct->ScanLimit);
	return MAX7219_WriteReg(MAX7219_ShutDown, MAX7219_InitStruct->ShutDown);
	MAX7219_InitStruct->DecodeMode=0xFF;	//code B 0..7
	MAX7219_InitStruct->Intensity=8;	//0...16
	MAX7219_InitStruct->ScanLimit=(DigitsPerChip-1);
	MAX7219_InitStruct->ShutDown=1;
	unsigned char ChipCNT;
	unsigned char DigitCNT = DigitsPerChip;
	for (DigitCNT=0;  DigitCNT!=DigitsPerChip; DigitCNT++)
		PIN_OFF(CS);
		for (ChipCNT=0; ChipCNT!=ChipsInSerial; ChipCNT++)
				SPI_SendByte(MAX7219_SPI, (DigitCNT+1));
				SPI_SendByte(MAX7219_SPI, Digit[(ChipsInSerial-ChipCNT-1)*DigitsPerChip+DigitCNT]);
		PIN_ON(CS);
	MAX7219_WriteReg(MAX7219_DisplayTest, Enable);
	MAX7219_WriteReg(MAX7219_Intensity, Intensity&0x0F);
	MAX7219_WriteReg(MAX7219_ShutDown, PowerState);
	unsigned char DigitArray[8];
	CHAR=CHAR<<1;
	DigitArray[0]=((*FONT)[CHAR]&0xFF000000)>>24;
	DigitArray[1]=((*FONT)[CHAR]&0x00FF0000)>>16;
	DigitArray[2]=((*FONT)[CHAR]&0x0000FF00)>>8;
	DigitArray[3]=((*FONT)[CHAR]&0x000000FF);
	DigitArray[4]=((*FONT+1)[CHAR]&0xFF000000)>>24;
	DigitArray[5]=((*FONT+1)[CHAR]&0x00FF0000)>>16;
	DigitArray[6]=((*FONT+1)[CHAR]&0x0000FF00)>>8;
	DigitArray[7]=((*FONT+1)[CHAR]&0x000000FF);
	MAX7219_DrawDigitSerial(DigitArray);
Thanks Easyrider83 for replying kindly also tel me about compiler???
Thanks for replying.
Sir tel me about best compiler for this code.
