Bluetooth consumes more power and may be a cause of worry during continuous operation for hours to gether.. So in terms of power consumption i would prefer zigbee to to more suitable over bluetooth....
you could use any controller in that matter for your project
if it is solved then please share the information so that it could be useful for others here............
you could use a self contained Zigbee device and communicate with it via a serial line, e.g. XBee
XBee-PRO® 802.15.4 OEM RF Modules - Digi International
you could use a Zigbee stack supplied by a microcontroller manufacturer, e.g. the Microchip Zigbee stack
these days I often use MiWi which is a simpler protocol than Zigbee
to save power you can supply the wireless device via a MOS FET which allows the microcontroller to switch off the device off when it is not being used
using an XBee you can connect it to the UART Tx and Rx lines and send commands to it to control the device
for Microchip's Zigbee have a look at the application notes on their web site
xbee is less power consumption compared to rf transceivers.... and its not hard to implement....
take a look at these vendors
N S K E L E C T R O N I C S
Sunrom Technologies, Your Source for Development
sir, what do you think of this? the controller has RF capability? https://ww1.microchip.com/downloads/en/DeviceDoc/70091a.pdf
the power consumption is still more than zigbee modules if it is run on a battery the power parameter will be a problem in RF...
Zigbee is complex and the modules do tend to be expensive (one reason why we gave up using it).
Have a look at Microchip's MiWi which is a simpler alternative using similar protocols
I dont know to whom you are asking about the solution .,,,,,,,,,,,, but it depends on your B.O.M and cost. Both low power and lost cost cannot be easily achieved... if you need both then go for RF transceiver IC by microchip..........
