PIC CONTROLLED DIGITAL CAPACITANCE METER
ebenni
Full Member level 1
Turkey
capacimetro pic
hi,
TOM McGAHEE'S PIC CONTROLLED DIGITAL CAPACITANCE METER Design & Software Copyright July 1999www.todopic.com.ar/asm/capacimetro/cmeter.pdf
Is this it? The titles are very simular :!:
Apparently it is the same one... it has the same archives.
And passing to something else... very interesting link.
remove 1999 from URL begin ! :)
I have downloaded this pdf now.
If somebody need C/V convertor with such parameters:
High precision capacitance-to-voltage conversion
• Digital programming of analog signal path
• Read-out of electrically floating capacitances
• Output voltage proportional to supply voltage
• Power-on reset sensor overload detection
• Bandwidth up to 10 kHz
• Resolves down to 0.25e-18 F/sqrt(Hz) at 5 V,
go to **broken link removed**
I can download now
thanks
1 warning sent (-5 posts , -20 points)
5 messages posted in this topic:
1) thank you
2) link not working
3) link not working
4) link not working
5) link now works
Very useful posts..... to download 83Mbytes eh ? :wink:
C Meter
This C Meter is really working per specifications.
I have build one. Only the relays are expensive.
Hy!
Here another C meter with 68HC711.
Regards
