PIC: Clear bit with bitnummer as variable?
msmax
Full Member level 1
Full Member level 1
Pays Bas
pic clear bit
Using MPLAB for a small project:
I like to clear a bit in a register using the value of an other register.
for example:
INCF Count,F
BCF Reg, Count
This doesn't seem to work, cause BCF only accepts literals.
Any idea how to do this in a easy way?
This can not work, you could define a table of the 8 bit positions
like
addwf pcl,F
retlw 0x01 or 0xFE if you want to clear Bit 0
retlw 0x02 or 0xFD if you want to clear Bit 1
and then call this routine with your "variable" in W
movf count,W
call xxxx
andwf Reg,F to clear bit X or iorwf Reg,F to set bit X
Complicated, but I have no other idea :)
best regards
Thanks for the info.
May be not the most simple routine, but it works fine for me.
Good THINKING!
other way "multiplication algorithm
use a dummy register f1
in f2 is the value of your bit. value is in orther 0 to 7
movlw b'11111111';
movwf f1
bcf status,c
loop rlf f1,f;
decfsz f2
goto loop
movf f1,w;
andwf yourfile
