Okada
Banned
I want to design a Buck Converter which converts High Voltage DC to 13.8 to 14.4V DC 20A for battery charging.
I will be using PIC18F26K22 for the project.
What voltage rated and current rated Mosfet and diode I have to use for Q1 and D1 ?
If by peak voltage at output of bridge is 270*1.4142 = 382V then does that mean that if I need 15V output then remaining voltage drops across inductor and Mosfet ? If yes, what will be the approx voltage drop across Mosfet drain to source ?
C1 is 1000 uF 50V
Bridge is 1kV 35A type (GBPC3510
C2 is 330uF 400V Electrolytic.
Circuit is attached.
Document I am referring is also attached.
Also to run a PIC and the IR21xx device I need 5V and 12V. How to get these voltages ? From 12V battery ?
C1 is 1000 uF 50V
