Raju C
Member level 2
HI GUYS
I AM DOING A PROGRAM FOR ANALOG RADIO SO IN THAT I AM USING A BINARY SWITCH FOR CHANNEL CHANGING , PROBLEM IS WHEN WE CHANGE THE CHANNEL IT SHOULD SEND PERTICULAR DATA BY CALCULATING IT IS OF 20 BITS..AND IN THIS FIRST 2 BITS ARE FIXED AND OTHER 4 ARE 0100 AND 0101 .. FOR THIS I HAVE TO UPLOAD OTHER 0-9 BITS AND 10 -19 BITS FROM THE MAIN DATA OF 16BITS .
EX: TAKE A ONE VALUE 03E85 THIS I NEED TO SPLIT INTO TWO VALUES AND I HAVE TO SEND AS BELOW
01 0100 (B9-B0)
01 0101 (B19-B10)
PLS CAN ANYONE SUGGEST HOW TO APPROACH FOR THAT
THANK YOU
Added after 4 hours 56 minutes:
PLS CAN ANY ONE HELP ME DOING PROGRAM ..FOR THE ABOVE THING WHAT I SAID ? PLS
01 0100 (B9-B0)
01 0101 (B19-B10)
THANK YOU
