PIC 16F877A interfacing with PIR sensor and DC motor
kmdineshece
Member level 1
Member level 1
Hi all!...............
pls, anyone help me!.....
I'm doing automatic welcome screen project,
when a person arrive, the screen should be open automatically,
harware connection was made, but my software has many malfunctions!........
pls help me for pin declaration,
assigning input and output pins!........
when PIR goes high it maintains the same state for few seconds, how can rectify this problem
I need HiTech C compiler based program
Can you share the circuit diagram and the code,which you have written till now..?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
#include <pic.h>
#include <math.h>
__CONFIG(0X1F71);
#include "lcd.h"
#define sensor_1 RB0
#define sensor_2 RB1
#define motor_1 RB2
#define motor_2 RB3
#define led RB4
void delay(unsigned int time) // Delay
    unsigned int i, j;
    for(i=0;i<time;i++)
       for(j=0;j<time;j++);
void main(void)
{   unsigned int result,temp,unit,a,b,c,d,x,y,z;
    x = 0;
    y = 0;
//  TRISA = 1;          // AN0 ADC channel as input
    TRISB0 = 1;         // port B as output
    TRISB1=1;
    TRISB2=0;
    TRISB3=0;
//PORTB=0xF0;
TRISB4=0;
    TRISC = 0;          // port C is  used for switches and relay
    TRISD = 0;          // port D as output
    lcdint();           // intialised LCD
    cmm(0x01);          // clear display
    cmm(0x80);          // 1'st line of LCD
    data_str(" SCIENTRIK ENGG ");
    delay(100);
    cmm(0xC0);          // 2'nd line of LCD
    data_str("    SOLUTIONS   ");
    delay(100);
    data_str(" WELCOME SCREEN ");
    delay(100);
    motor_1=0;
    motor_2=0;
delay(300);
led=0;
while(1)
if((RB1==1) || (RB0==1))
    data_str("   SENSOR 1&2  ");
    motor_1=1;
    delay(170);
    motor_1=0;
    led=1;
    while((RB1==1) || (RB0==1))
    data_str("   SENSOR_out  ");
    led=0;
    motor_2=1;
    delay(170);
    motor_2=0;
if((RB1==0) && (RB0==0))
    motor_1=0;
    motor_2=0;
    data_str("   NO MOTION  ");
    led=0;
