Pic 16f877A Hex file
AboudaKing
Member level 1
Member level 1
#I'm begginer in real application#
Im working on pic16f877A based project, sumilation in PROTEUS works fine and as desired.
I just bought a pickit3 to make it in real, seted up tje pickit3 for 40dip ic and used mplab IPE to upload hex file
For start i used blinking led hex file, uploaded sucssefully into pic16f877A.
Now for the BreadB, what schematici can use i googeled it and found several schematics
What is the optimal schematic and values for capacitors aeound the crystal and resistor values if needed
Question: i have 2 mcu's one of them i mistakenly bended the first pin 'MCLR' while puting it in dip support and it's a bad bend if i fix it it'll fall off is it possible to solder it back !?
Thank you
a breadboard is not suitable for XTAL circuits. It generally is not suitable for reliable high frequency signals.
--> use a development board / breakout board.
Klaus
    AboudaKing
    AboudaKing
I have no idea what OCS means.
Be a little more attentive on your posts, there are several typos.
To use a crystal frequency above about 4 MHz on a breadboard is not workable, you should use the internal oscillator instead.
I'm not clear on exactly what the issue is (other than the MCLR pin!). What does your code do? That will help us advise you on some other parts of your circuit.
To program the chip you do not need an oscillator - the PicKit3 will provide the PGC/PGD/PGM signals and they are enough to program the chip. Running (and/or debugging) your code is a different matter and you certainly will need and oscillator set up.
Susan
For breadboarding PIC16F877A, I used 20MHZ crystal oscillators and 22pF ceramic capacitors. MCLR pin was pulled up with a 1K resistor.
Thank you
Hi
If your MCLR pin is bended so you should give first attention to corrected it because MCLR is the key pin for both Programming and running the Microcontroller.
In the case of soldering the MCLR pin ....Yes......you can solder it using recommended soldering method , I would suggest you first heat the soldering iron then remove it wire from AC supply then solder the MCLR pin .
For further help please post your code and the circuit diagram that you are going to use and you can easily search it on the google then you can find lot of schematics in which most of them are working
PA3041
