AboudaKing
Member level 1
i'm working on project with pic 16f877 that is connected to terminal blocks so i can control outputs related to them
simulation and my program works fine , however i'm wondering if my schematics are correct or if i need any other change before i order a PCB board from manufacturer
- the MP2-3 and logic states are all slide buttons to control outputs
- U5 is the reset button
- U2 is 5v regulator 7805
- U3 slide button ON/OFF
- MP1 mount block for power source
- MP4-5 mount block for outputs
- if i'm using 5V/3A power supply how thick the traces in PCB need to be to avoid overheating ?
