PIC 16F84A Display Data Interface Problem, please help!
desmop
Newbie level 3
Newbie level 3
mplasm #define pin
Hello,
This is my first post to this forum, so bear with me. I'm working on writing assembly code for a R/C microturbine tachometer. I'm very new to this so, I really could use some help. I'm using the PIC 16F84A micro controller chip, compling the language with MPLAb IDE v 7.30 and assembling the data with Mplasm. I'm having a problem displaying more data on my 8 x 2 LCD I can display only 5 digits plus the tag "RPM". Only the first 3 are data filled digits the last two are just printed zeros. The way I have the program written is that it displays Rpm's in 100's. There is on the second line of the display a slectable number of blades. I want to be able to display over 99,900 rpms but I can figure the correct method to do it. I keep going in circles and need some help from those that have the experience. I've attached the ASM file for evaluation and suggestions. Thanks in advance!
Interesting project, but I can't see any attachment :/
The fact that your LCD is displaying something, even the zero's means theres nothing wrong with your LCD routines.
Sounds pretty complicated....timers/counters etc.. I assume you have a routine that takes in the values from your counter (for your tach) and converts it to BCD (binary coded decimal) and then converts it to ASCII for your LCD.
it seems its the conversion process thats giving you trouble. Possibly the BCD bit. But dealing with counters/timers can be tricky as well since you need to convert it to a number for 'RPM' (dealing in minute timmebase).
Post your code, and I'll have a look, can't promise anything...I'm still an amatuer with PICs really.
BuriedCode.
Code posted for PIC 16F84A Display Data Interface problem.....
LIST P=16F84A,R=HEX ; 16F84A Runs at 4 MHz
; INCLUDE "P16F84A.inc"
; LCD TACHOMETER FOR R/C MODEL TURBINE ENGINE
; DESMOND, P
; 16F84A Pin Out
; Pin 1: RA2 Pin 10: RB4
; Pin 2: RA3 Pin 11: RB5
; Pin 3: RA4/T0CKI Pin 12: RB6
; Pin 4: MCLR Pin 13: RB7
; Pin 5: VSS +5V Pin 14: VDD +5v
; Pin 6: RB0/INT Pin 15: OSC2/CLKOUT
; Pin 7: RB1 N/A Pin 16: OSC1/CLKIN
; Pin 8: RB2 Pin 17: RA0
; Pin 9: RB3 Pin 18: RA1
; VERSION 3.25: 05/11/2006 UPDATE FOR KJ66
;-------SYSTEM---------------------
__CONFIG H'3FF1'
;-------DEFINE RAM------------
TMR0 EQU 1 ;TIMER 0
PC EQU 2 ;PROGRAM COUNTER
STATUS EQU 3
FSR EQU 4 ;BUFFER OF INDIRECT ADDR
PORTA EQU 5
PORTB EQU 6
EEDATA EQU 8 ;EEPROM DATA
EEADR EQU 9 ;EEPROM ADDR
PCLATH EQU H'A'
INTCON EQU H'B' ;INTERRUPT CONTROL
OPTIONF EQU 1 ;0X81
TRISA EQU 5 ;0X85
TRISB EQU 6 ;0X86
EECON1 EQU 8 ;0X88 IS EEPROM CONTROL1
EECON2 EQU 9 ;0X89 IS EEPROM CONTROL2
;-------DEFINE BIT-------------
C EQU 0
W EQU 0 ;d VALUE FOR INCF......
F EQU 1 ;d VALUE
OFF EQU 0 ;FLAG BIT 0,
RP0 EQU 5 ;STATUS BIT 5 & 6 =REGISTER BANK SELECT
RP1 EQU 6
INPUT EQU 7 ;RB7 AS INPUT PORT
TOIF EQU 2 ;INTCON TMR0 OVERLOW INT FLAG
TOIE EQU 5 ;INTCON TOIF ENABLE
GIE EQU 7 ;INTCON GLOBAL INT ENABLE
;-------USER-------------------------------------
;-------REGISTERS------
TCNT0 EQU H'C' ;= (0.6SEC /INT* PRESCAL*CLOCK)
INTR0 EQU H'D' ;AFTER INT, SAVE W VALUE
INTR1 EQU H'E' ;AFTER INT, SAVE STATUS
DD1 EQU H'F' ;DATA FOR INPUT RPM
DD2 EQU H'10'
DD3 EQU H'11'
TEMP1 EQU H'12' ;
TEMP2 EQU H'13'
TEMP3 EQU H'14'
SLOW_C EQU H'15' ;100-200 +- 1 EVERY INT_DST
INT_C EQU H'16' ;0-255 -1 EVERY INT_DST
FLAG_REG EQU H'17'
MODE_SEL EQU H'18'
PWM_C EQU H'19'
PUSH_C EQU H'1A'
RAND_HI EQU H'1B'
RAND_LO EQU H'1C'
TCNT EQU H'1D'
;-------BIT----------------
F_ON EQU 0
F_UP EQU 1
F_TDST EQU 2
F_REC EQU 3
TACHO_SEL EQU 4
;-------VARIABLES-----------
TMR EQU D'181' ;(PRESCALE 64*1uS) * 75 = 4800 uS
TCNT_2 EQU D'125' ;4.8mS*125=600mS,BUT FIX SOME ODD CODE
TCNT_3 EQU D'84' ;THIS TWO * PRESCALE 1:64,TO A 0.6 SECOND DURATION
TCNT_4 EQU D'62'
TCNT_5 EQU D'50'
BDELAY EQU D'40'
TMR1 EQU D'178' ;(PRESCALE 256*78) = 19968 uS
RLIMIT EQU D'200' ;SERVO LIMIT
LLIMIT EQU D'100'
;-------LCD SOUTINE-------------------------
;-------REGISTERS---------
ADDRESS1 EQU H'41'
CHAR1 EQU H'42'
TEMP1_LCD EQU H'43'
TEMP2_LCD EQU H'44'
TEMP3_LCD EQU H'45'
TEMP4_LCD EQU H'46'
TABLE_INDEX EQU H'47' ;
;========== MAIN PROGRAM =========
ORG 0
PAGESEL START
GOTO START
ORG 4 ;INTERRUPT BEGIN
INTB MOVWF INTR0 ; SAVE W
MOVF STATUS,W ; SAVE STATUS
MOVWF INTR1
BCF STATUS,RP0 ; MAKE SURE SELECT BANK0
CHECK_TDST
BTFSC FLAG_REG,F_TDST ;IF SET GOTO DST MODE
GOTO INT_DST
;----- TACHOMETER INTERRUPT -----------
INT_TACHO
MOVLW TMR ; RESTORE TIMER0
MOVWF TMR0 ;
DECFSZ TCNT0,F ;SKIP IF ZERO
GOTO INTEND
RELOAD MOVF TCNT,W ;RELOAD TCNT0
MOVWF TCNT0
DISP_RPM
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW B'00110000'
IORWF DD1,1
IORWF DD2,1
IORWF DD3,1
MOVFW DD1
CALL PRINT_CHAR
MOVFW DD2
CALL PRINT_CHAR
MOVFW DD3
CALL PRINT_CHAR
MOVLW '0'
CALL PRINT_CHAR
MOVLW '0'
CALL PRINT_CHAR
MOVLW 'R'
CALL PRINT_CHAR
MOVLW 'P'
CALL PRINT_CHAR
MOVLW 'M'
CALL PRINT_CHAR
RESET_COUNT
CLRF DD1 ;DISPLAY DATA
CLRF DD2
CLRF DD3
;------ LEAF MODE SELECT --------
BTFSS PORTA,1 ;SELECT ?
BSF FLAG_REG,TACHO_SEL
MOVWF TMR0 ;
GOTO INTEND
;------ END OF TACHO INT ---------
INT_DST
MOVLW TMR1 ;256*78=19968 uS
MOVWF TMR0
MOVF PWM_C,W
MOVWF TEMP1
BIN2BCD MOVWF DD3 ;1
CLRF DD2 ;10
CLRF DD1 ;100
H1 MOVLW 0X64 ; 100
SUBWF DD3,F ; SUBTRACT 100 FROM NUMBER
BTFSC STATUS,C ; NEGATIVE RESULT?
GOTO H2 ; NO? GOTO H2
GOTO H3 ; YES? GOTO H3 (100'S DDD3)
H2 INCF DD1,F ; INCREMENT DD1 REGISTER
GOTO H1 ; & LOOP BACK FOR ANOTHER TEST
H3 MOVLW 0X64 ; 100
ADDWF DD3,F ; ADD 100 BACK TO NUMBER
T1 MOVLW 0X0A ; 10
SUBWF DD3,F ; SUBTRACT 10 FROM NUMBER
GOTO T2 ; NO? GOTO T2
GOTO T3 ; YES? GOTO T3 (10'S DDD3)
T2 INCF DD2,F ; INCREMENT DD2 REGISTER
GOTO T1 ; & LOOP BACK FOR ANOTHER TEST
T3 MOVLW 0X0A ; 10
ADDWF DD3,F ; ADD 10 BACK TO NUMBER
MOVLW H'40'
CALL DDRAM_ADDRESS
MOVLW B'00110000'
IORWF DD1,1
IORWF DD2,1
IORWF DD3,1
MOVLW ' '
CALL PRINT_CHAR
MOVFW DD1
CALL PRINT_CHAR
MOVFW DD2
CALL PRINT_CHAR
MOVFW DD3
CALL PRINT_CHAR
MOVLW '0'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW 'u'
CALL PRINT_CHAR
MOVLW 'S'
CALL PRINT_CHAR
BTFSC FLAG_REG,F_REC
GOTO INTEND
BSF PORTA,3
INT_DST1 ;10 uS LOOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
DECFSZ TEMP1,F
GOTO INT_DST1 ;END OF LOOP
BCF PORTA,3
DECF INT_C,F ;INCREASE INT_COUNTER
INTEND
MOVF INTR1,W ; RESTORE STATUS
MOVWF STATUS
MOVF INTR0,W ; RESTORE W
BCF INTCON,TOIF ; RESET FLAG OF INT T0
RETFIE
;LCD SOUTINE
PRINT_DATA
BSF PORTB,2 ;RS=1, DATA
MOVWF ADDRESS1
BSF ADDRESS1,2
MOVF ADDRESS1,0
MOVWF PORTB
BSF PORTB,3
NOP
BCF PORTB,3
CALL LOOP_S ;100 uS
RETURN
PRINT_CONT
MOVWF PORTB
BSF PORTB,3
BCF PORTB,3
CALL LOOP_S ;100 uS
RETURN
CLEAR_DISPLAY
MOVLW B'00000000' ;0
CALL PRINT_CONT
MOVLW B'00010000' ;1 CLEAR
CALL PRINT_CONT
MOVLW 1
CALL LOOP_L ;10mS
RETURN
DDRAM_ADDRESS
MOVWF ADDRESS1
BSF ADDRESS1,7
MOVF ADDRESS1,0
ANDLW B'11110000' ;
CALL PRINT_CONT
SWAPF ADDRESS1,W ;SWAP HALVES F
ANDLW B'11110000' ;
CALL PRINT_CONT
RETURN
PRINT_CHAR
MOVWF CHAR1
ANDLW B'11110000' ;
CALL PRINT_DATA
SWAPF CHAR1,W ;SWAP HALVES F
ANDLW B'11110000' ;SENT LOW 4 BITS
CALL PRINT_DATA
RETURN
LOOP_S ;100uS LOOP
MOVLW D'33'
MOVWF TEMP4_LCD
LOOP_S1
DECFSZ TEMP4_LCD,1 ;
GOTO LOOP_S1
RETURN
LOOP_L ;10 mS LOOP
MOVWF TEMP1_LCD
LOOP_L1
MOVLW D'10' ;10 mS
MOVWF TEMP2_LCD
LOOP_L2
MOVLW D'249' ;(249*4)+5=1001
MOVWF TEMP3_LCD
LOOP_L3
NOP
DECFSZ TEMP3_LCD,1
GOTO LOOP_L3
DECFSZ TEMP2_LCD,1
GOTO LOOP_L2
DECFSZ TEMP1_LCD,1
GOTO LOOP_L1
RETURN
DISP_MESSAGE
MOVWF TABLE_INDEX ;W -> INDEX, THE BEGIN OF MESSAGE
CALL MESSAGE1
ANDLW 0FFH
SKPNZ ; IF TABLE RETURN 0 , END OF MESSAGE SECTION
RETURN
CALL PRINT_CHAR ; DOSPLAY
INCF TABLE_INDEX,0
GOTO DISP_MESSAGE
MODE_ADDRESS
ADDWF PC,F
RETLW 0
RETLW 0
RETLW D'9'
RETLW D'18'
RETLW D'27'
MESSAGE1
ADDWF PC,F
RETLW 'T'
RETLW 'a'
RETLW 'c'
RETLW 'h'
RETLW 'o'
RETLW ' '
RETLW ' '
RETLW ' '
RETLW 0
RETLW 'S' ;9
RETLW 'e'
RETLW 'r'
RETLW 'v'
RETLW 'o'
RETLW ' '
RETLW 'T'
RETLW 'x'
RETLW 0
RETLW 'S' ;18
RETLW 'p'
RETLW 'e'
RETLW 'e'
RETLW 'd'
RETLW ' '
RETLW 'T'
RETLW 'x'
RETLW 0
RETLW 'R' ;27
RETLW 'e'
RETLW 'c'
RETLW 'e'
RETLW 'i'
RETLW 'v'
RETLW 'e'
RETLW 'r'
RETLW 0
NOP ;36
;---------- PROGRAM BEGIN -----------
START
BSF STATUS,RP0 ;SET 3,5 ENABLE BANK1
MOVLW B'00000001'
MOVWF TRISB ;SET RB 1-7 OUTPUT, 0 INPUT
MOVLW B'00000111'
MOVWF TRISA ;SET RA0-RA2 INTPUT, RA3,RA4 OUTPUT
BCF STATUS,RP0 ;ENABLE BANK0
BCF PORTA,3 ;OUT PWM
BSF PORTA,4 ;OUT +5V OFF
CLRF PORTB
BCF INTCON,GIE
CLRF FLAG_REG
MOVLW D'150'
MOVWF PWM_C
INIT_LCD
MOVLW 5 ;POWER ON DELAY 50mS
CALL LOOP_L
SET_4BIT_MOD ;SET LCD AT 4 BIT MODEL
MOVLW B'00110000' ;3
CALL PRINT_CONT
MOVLW 1
CALL LOOP_L ;10mS
CALL PRINT_CONT
CALL PRINT_CONT
MOVLW B'00100000' ;2, 4BIT MODE
CALL PRINT_CONT
CALL PRINT_CONT
MOVLW B'10000000' ;8 4BITS, 2 LINES, FONT 0
CALL PRINT_CONT
INIT_DISPLAY
MOVLW B'00000000' ;O
CALL PRINT_CONT
MOVLW B'11000000' ;C SCREEN ON, NO CURSOR, NO BLINKING
CALL PRINT_CONT
CALL CLEAR_DISPLAY ;CLEAR DISPLAY
MOVLW ' '
CALL PRINT_CHAR
MOVLW 'K'
CALL PRINT_CHAR
MOVLW 'J' ;DISPLAY FIRST SECTION MESSAGE
CALL PRINT_CHAR
MOVLW '-'
CALL PRINT_CHAR
MOVLW '6'
CALL PRINT_CHAR
MOVLW '6'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW H'40'
CALL DDRAM_ADDRESS
MOVLW 'D'
CALL PRINT_CHAR
MOVLW 'S'
CALL PRINT_CHAR
MOVLW 'T'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW 'V'
CALL PRINT_CHAR
MOVLW '3'
CALL PRINT_CHAR
MOVLW '.'
CALL PRINT_CHAR
MOVLW '2'
CALL PRINT_CHAR
MOVLW D'150'
CALL LOOP_L ;DELAY 3.0 SECOND
CLRF MODE_SEL
INCF MODE_SEL,F
MMODE_00
MOVLW H'40'
CALL DDRAM_ADDRESS
MOVFW MODE_SEL
CALL MODE_ADDRESS ;GET MODE NAME BEGINING
CALL DISP_MESSAGE ;DISPLAY MODE NAME
MOVLW D'50'
CALL LOOP_L ;1.0 SECOND CHANGE MODE
BTFSS PORTA,1
GOTO MMODE_01 ;+ PUSH, NEXT MODE
BTFSS PORTA,0
GOTO MMODE_02 ;SELECT PUSH,
GOTO MMODE_00
MMODE_01
INCF MODE_SEL,F
MOVLW 5 ;MODE_SEL 1-4 ONLY
SUBWF MODE_SEL,W
SKPZ
GOTO MMODE_00
MOVLW 1
MOVWF MODE_SEL
GOTO MMODE_00
MMODE_02
;-------ON MODE_SEL GOTO----------
MOVLW 1
SUBWF MODE_SEL,W
SKPNZ
GOTO MAIN ;1 TACHO
MOVLW 2
SUBWF MODE_SEL,W
SKPNZ
GOTO DST_MAIN ;2 DST
MOVLW 3
SUBWF MODE_SEL,W
SKPNZ
GOTO SCT_MAIN ;3 SCT
MOVLW 4
SUBWF MODE_SEL,W
SKPNZ
GOTO RECT_MAIN ;4 RECT
MAIN
MOVLW 0
CALL DDRAM_ADDRESS
MOVLW 1
MOVLW B'10000101'
MOVWF OPTIONF ;INTERNAT CLOCK,TRM0,1:64
CLRF DD2
CLRF DD3
MOVLW 1 ;DEFAULT 2 LEAVES
MOVWF MODE_SEL
GOTO T_SEL
MAIN01
MOVLW TMR ;75
MOVWF TMR0
MOVLW TCNT ;DEPEND ON LEAVES
MOVWF TCNT0
BCF INTCON,TOIF
BSF INTCON,TOIE
BSF INTCON,GIE ;ENABLE INT
MAIN1
BTFSC FLAG_REG,TACHO_SEL
GOTO T_SEL
BTFSS PORTA,2
GOTO START
BTFSC PORTA,0 ;IF INPUT=0, SKIP
GOTO MAIN1
MAIN2
GOTO T_SEL
BTFSS PORTA,2
GOTO START
BTFSS PORTB,0 ;IF INPUT=1, SKIP
GOTO MAIN2
MAIN3 INCF DD3,F
MOVLW H'0A'
SUBWF DD3,W
SKPZ ;DIGITAL 1 =A, MUST AJUST
GOTO MAIN1
CLRF DD3
INCF DD2,F
MOVLW H'0A'
SUBWF DD2,W
GOTO MAIN1
CLRF DD2
INCF DD1,F ;DIGITAL 3 WILL NOT >9, SO NO CHECK
GOTO MAIN1
;------ TACHO MODE SELECT -----------
T_SEL
BCF FLAG_REG,TACHO_SEL
BCF INTCON,GIE
INCF MODE_SEL,F
MOVLW 6 ;MODE_SEL 2-5 ONLY
SUBWF MODE_SEL,W
SKPZ
GOTO T_SEL1
MOVLW 2
MOVWF MODE_SEL
T_SEL1
MOVLW H'40'
CALL DDRAM_ADDRESS
MOVLW H'30' ;CONVERT HEX TO ASCII
ADDWF MODE_SEL,W ;CONVERT HEX TO ASCII
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW 'B'
CALL PRINT_CHAR
MOVLW 's'
CALL PRINT_CHAR
MOVLW 2
SUBWF MODE_SEL,W
SKPNZ
GOTO TMODE_2 ;2 LEAVES
MOVLW 3
SUBWF MODE_SEL,W
SKPNZ
GOTO TMODE_3 ;3
MOVLW 4
SUBWF MODE_SEL,W
SKPNZ
GOTO TMODE_4 ;4
TMODE_5 ;5
MOVLW TCNT_5
MOVWF TCNT
GOTO T_SEL_5
TMODE_4
MOVLW TCNT_4
MOVWF TCNT
GOTO T_SEL_5
TMODE_3
MOVLW TCNT_3
MOVWF TCNT
GOTO T_SEL_5
TMODE_2
MOVLW TCNT_2
MOVWF TCNT
GOTO T_SEL_5
T_SEL_5
MOVLW D'50' ;0.01 SECOND *50
CALL LOOP_L
BTFSS PORTA,1
GOTO T_SEL ;CHANGE MODE
GOTO MAIN01
;------ END OF TACHOMETER --------------
DST_MAIN
BCF PORTA,4 ;OUT +5V TURN ON
BSF FLAG_REG,F_TDST ;IF SET GOTO DST MODE
MOVLW 0
CALL DDRAM_ADDRESS
;-------SETUP_INTERRUPT-------
MOVLW B'10000111'
MOVWF OPTIONF ;INTERNAT CLOCK,TRM0,1:256
MOVWF TMR0
BCF INTCON,TOIF
BSF INTCON,TOIE
CLRF MODE_SEL
MODE_0
INCF MODE_SEL,F
MOVLW 7 ;MODE_SEL 1-5 ONLY
SUBWF MODE_SEL,W
SKPZ
GOTO MODE_01
MOVLW 1
MOVWF MODE_SEL
MODE_01
MOVLW 1
SUBWF MODE_SEL,W
SKPNZ
GOTO MODE_1 ;MANUAL
MOVLW 2
SUBWF MODE_SEL,W
SKPNZ
GOTO MODE_3 ;FSAT
MOVLW 3
SUBWF MODE_SEL,W
SKPNZ
GOTO MODE_4 ;MIDDLE
MOVLW 4
SUBWF MODE_SEL,W
SKPNZ
GOTO MODE_2 ;SLOW
MOVLW 5
SUBWF MODE_SEL,W
SKPNZ
GOTO MODE_5 ;RANDOM
GOTO MODE_6 ;ESCAPE
MODE_1
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'M'
CALL PRINT_CHAR
MOVLW 'a'
CALL PRINT_CHAR
MOVLW 'n'
CALL PRINT_CHAR
MOVLW 'u'
CALL PRINT_CHAR
MOVLW 'a'
CALL PRINT_CHAR
MOVLW 'l'
CALL PRINT_CHAR
MOVLW BDELAY
CALL LOOP_L
MODE_10
MOVLW D'150'
MOVWF PWM_C
MODE_11
BTFSS PORTA,0
GOTO INC_B
BTFSS PORTA,2
GOTO DEC_B
BTFSS PORTA,1
GOTO CENT_B
CLRF PUSH_C
GOTO MODE_11
INC_B MOVLW RLIMIT
SUBWF PWM_C,W
SKPNZ
GOTO MODE_11 ;=RLIMIT, DO NOTHING
INCF PWM_C,F
MOVLW D'5' ;CONTINUE 5 STEP, ACCELERATION
SUBWF PUSH_C,W
SKPNZ
GOTO INC_B1 ;
MOVLW D'20' ;0.2 SECOND
CALL LOOP_L ;CALL 0.1 SECOND LOOP
INCF PUSH_C,F
GOTO MODE_11
INC_B1 ;FAST INC
MOVLW D'6'
CALL LOOP_L ;0.06 SECOND
GOTO MODE_11
DEC_B
MOVLW LLIMIT
SUBWF PWM_C,W
SKPNZ
GOTO MODE_11 ;=LLIMIT, DO NOTHING
DECF PWM_C,F
SUBWF PUSH_C,W
SKPNZ
GOTO DEC_B1 ;
MOVLW D'20' ;
INCF PUSH_C,F
GOTO MODE_11
DEC_B1 ;FAST DEC
MOVLW D'6'
GOTO MODE_11
CENT_B
MOVLW BDELAY ;0.01 SECOND * 40
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_0 ;CHANGE MODE
GOTO MODE_10
MODE_2
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'S'
CALL PRINT_CHAR
MOVLW 'l'
CALL PRINT_CHAR
MOVLW 'o'
CALL PRINT_CHAR
MOVLW 'w'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MODE_20 ;SLOW 10 SECOND
MOVLW D'150'
MOVWF PWM_C
BSF FLAG_REG,F_UP
MODE_21
BTFSS PORTA,0
GOTO INC_B2
BTFSS PORTA,2
GOTO MODE_21
BTFSS PORTA,1
GOTO CENT_B2
GOTO MODE_21
INC_B2
MOVLW 2 ; 2 TIMES
MOVWF PUSH_C
MOVLW 5
MOVWF INT_C
INC_B21
MOVF INT_C,W ;5*100*20mS = 10 SECOND
SKPZ
GOTO INC_B21
MOVLW 5 ;5*100*20mS = 10 SECOND
MOVWF INT_C
BTFSS FLAG_REG,F_UP ;UP / DOWN ?
GOTO INC_B23 ;COUNT_DOWN
INC_B22
MOVLW RLIMIT ;UP
SUBWF PWM_C,W
SKPNZ
GOTO INC_B24 ;TURN_DOWN
INCF PWM_C,F
BTFSS PORTA,2 ;STOP ?
GOTO MODE_21
GOTO INC_B21
INC_B24 ;TURN_DOWN
BCF FLAG_REG,F_UP
INC_B23
MOVLW LLIMIT ;
SUBWF PWM_C,W
SKPNZ
GOTO INC_B25 ;TURN_UP
DECF PWM_C,F
GOTO MODE_21
GOTO INC_B21
INC_B25
BSF FLAG_REG,F_UP
DECF PUSH_C,F
SKPNZ
GOTO MODE_21
GOTO INC_B22
CENT_B2
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_20
MODE_3
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'F'
CALL PRINT_CHAR
MOVLW 'a'
CALL PRINT_CHAR
MOVLW 's'
CALL PRINT_CHAR
MOVLW 't'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR ;FAST 0.5 SECOND
MODE_30
MOVLW D'150'
MOVWF PWM_C
MODE_31
BTFSS PORTA,0
GOTO INC_B3
BTFSS PORTA,2
GOTO MODE_31
BTFSS PORTA,1
GOTO CENT_B3
GOTO MODE_31
INC_B3
MOVLW 5
MOVWF PUSH_C
INC_B31
MOVLW RLIMIT
MOVWF PWM_C
BTFSS PORTA,2
GOTO MODE_3
MOVLW D'45' ;0.45SECOD +22 INTERRUPT
MOVLW LLIMIT
MOVWF PWM_C
BTFSS PORTA,2
GOTO MODE_3
MOVLW D'45'
CALL LOOP_L
DECFSZ PUSH_C,F
GOTO INC_B31
GOTO MODE_3
CENT_B3
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_30
MODE_4 ;MID 2 SECOND
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'M'
CALL PRINT_CHAR
MOVLW 'i'
CALL PRINT_CHAR
MOVLW 'd'
CALL PRINT_CHAR
MOVLW 'd'
CALL PRINT_CHAR
MOVLW 'l'
CALL PRINT_CHAR
MOVLW 'e'
CALL PRINT_CHAR
MODE_40
MOVLW D'150'
MOVWF PWM_C
BSF FLAG_REG,F_UP
MODE_41
BTFSS PORTA,0
GOTO INC_B4
BTFSS PORTA,2
GOTO MODE_41
BTFSS PORTA,1
GOTO CENT_B4
GOTO MODE_41
INC_B4
MOVLW 5 ; 5 TIMES
MOVWF PUSH_C
MOVLW 1
MOVWF INT_C
INC_B41
MOVF INT_C,W ;1*100*20mS = 2 SECOND
SKPZ
GOTO INC_B41
MOVLW 1 ;1*100*20mS = 2 SECOND
MOVWF INT_C
GOTO INC_B43 ;COUNT_DOWN
INC_B42
MOVLW RLIMIT ;UP
SUBWF PWM_C,W
SKPNZ
GOTO INC_B44 ;TURN_DOWN
INCF PWM_C,F
GOTO MODE_41
GOTO INC_B41
INC_B44 ;TURN_DOWN
BCF FLAG_REG,F_UP
INC_B43
MOVLW LLIMIT ;
SUBWF PWM_C,W
SKPNZ
GOTO INC_B45 ;TURN_UP
DECF PWM_C,F
GOTO MODE_41
GOTO INC_B41
INC_B45
BSF FLAG_REG,F_UP
DECF PUSH_C,F
SKPNZ
GOTO MODE_41
GOTO INC_B42
CENT_B4
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_40
MODE_5 ;Random
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'R'
CALL PRINT_CHAR
MOVLW 'a'
CALL PRINT_CHAR
MOVLW 'n'
CALL PRINT_CHAR
MOVLW 'd'
CALL PRINT_CHAR
MOVLW 'o'
CALL PRINT_CHAR
MOVLW 'm'
CALL PRINT_CHAR
MODE_50
MOVLW D'150'
MOVWF PWM_C
MODE_51
DECFSZ RAND_LO,F ;RANDOM SEED GENERATOR
GOTO MODE_52
DECF RAND_LO,F ;MAKE SURE NO ZERO
DECFSZ RAND_HI,F
GOTO MODE_52
DECF RAND_HI,F ;MAKE SURE NO ZERO
MODE_52 BTFSS PORTA,0
GOTO INC_B5
BTFSS PORTA,2
GOTO MODE_51
BTFSS PORTA,1
GOTO CENT_B5
GOTO MODE_51
INC_B5
MOVLW H'20' ;20-30 RANDOM TEST
MOVWF PUSH_C
INC_B51
MOVLW D'10' ;10 PULSES PER POSITION
MOVWF INT_C
RANDOM16
RLF RAND_HI,W
XORWF RAND_HI,W
RLF TEMP1,F
SWAPF RAND_HI,F
SWAPF RAND_LO,W
RLF TEMP1,F
XORWF RAND_HI,W
SWAPF RAND_HI,F
ANDLW 0x01
RLF RAND_LO,F
XORWF RAND_LO,F
RLF RAND_HI,F
MOVLW RLIMIT
SUBWF RAND_LO,W
SKPNC ;F<W , C=0
GOTO RANDOM16
MOVLW LLIMIT
SUBWF RAND_LO,W
SKPC ;F>W , C=1
GOTO RANDOM16
MOVF RAND_LO,W
MOVWF PWM_C
INC_B52
MOVF INT_C,W
SKPZ
GOTO INC_B52
GOTO MODE_5
DECFSZ PUSH_C,F
GOTO INC_B51
GOTO MODE_51
CENT_B5
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_50
MODE_6 ;Random
MOVLW H'0'
CALL DDRAM_ADDRESS
MOVLW 'Q'
CALL PRINT_CHAR
MOVLW 'u'
CALL PRINT_CHAR
MOVLW 'i'
CALL PRINT_CHAR
MOVLW 't'
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MOVLW ' '
CALL PRINT_CHAR
MODE_61
BTFSS PORTA,0
GOTO START
BTFSC PORTA,1
GOTO MODE_61
MOVLW BDELAY
CALL LOOP_L
BTFSS PORTA,1
GOTO MODE_0
GOTO MODE_61
;------ END OF DST ---------------
;----- SPEED CONTROLLER TESTER --
SCT_MAIN
MOVLW 0
CALL DDRAM_ADDRESS
MOVFW MODE_SEL
MOVLW BDELAY
CALL LOOP_L
MOVLW B'10000111'
MOVWF TMR0
BCF INTCON,TOIF
BSF INTCON,TOIE
SCT_1
MOVLW D'100' ;MINIMUM
MOVWF PWM_C
SCT_11
BTFSS PORTA,0
GOTO ISCT_B
BTFSS PORTA,2
GOTO DSCT_B
BTFSS PORTA,1
GOTO DCENT_B
CLRF PUSH_C
GOTO SCT_11
ISCT_B MOVLW RLIMIT
SUBWF PWM_C,W
SKPNZ
GOTO SCT_11 ;=RLIMIT, DO NOTHING
INCF PWM_C,F
SUBWF PUSH_C,W
SKPNZ
GOTO ISCT_B1 ;
INCF PUSH_C,F
GOTO SCT_11
ISCT_B1 ;FAST INC
MOVLW D'6'
GOTO SCT_11
DSCT_B
MOVLW LLIMIT
SUBWF PWM_C,W
SKPNZ
GOTO SCT_11 ;=LLIMIT, DO NOTHING
DECF PWM_C,F
SUBWF PUSH_C,W
SKPNZ
GOTO DSCT_B1 ;
MOVLW D'20' ;
INCF PUSH_C,F
GOTO SCT_11
DSCT_B1 ;FAST DEC
MOVLW D'6'
GOTO SCT_11
DCENT_B
CALL LOOP_L
BTFSS PORTA,1
GOTO START ;CHANGE MODE
GOTO SCT_1 ;GOTO BEGINING, 1000uS
;------ END OF SCT -----------------
RECT_MAIN
BSF FLAG_REG,F_TDST
BSF FLAG_REG,F_REC
MOVLW 0
CALL DDRAM_ADDRESS
MOVFW MODE_SEL
BSF STATUS,RP0 ;
MOVLW B'10000000'
MOVLW B'00001111' ;SET RA,3 INPUT
MOVWF TRISA ;
BCF STATUS,RP0 ;
CLRF PWM_C
BSF INTCON,TOIE
BSF INTCON,GIE ;ENABLE INT TO DISPLAY XXX uS
NOP
NOP
REC_0
BCF INTCON,TOIF
BCF INTCON,TOIE
BCF INTCON,GIE ;
;-------START MEASURE-------------
REC_2
CLRF PWM_C
REC_3
BTFSS PORTA,1
GOTO REC_B
BTFSS PORTA,3
GOTO REC_3
REC_4
NOP ;10 uS LOOP
NOP
NOP
NOP
INCF PWM_C,F
SKPNZ
GOTO REC_ERROR ;IF PWM_C > 255, ERROR
BTFSC PORTA,3
GOTO REC_4
DECF PWM_C,F ;CORRECT 1-20 uS
GOTO REC_5
REC_ERROR ;IF > 255 DISPLAY 255
MOVLW H'FF'
MOVWF PWM_C
REC_5
BSF INTCON,TOIE
GOTO REC_0
REC_B
CALL LOOP_L
BTFSS PORTA,1
GOTO START ;CHANGR MODE TO SCT MAUN
GOTO RECT_MAIN
END
